Tip & How-To about Computers & Internet
How to delete Microsoft Windows, how to remove Windows
In this tech article I will go over how to remove Microsoft Windows or revert to a previous version of Windows. Why would you want to delete Windows? You may want to remove Windows because you do not like that version you have installed, or maybe you want a different operating system like Linux.
In my method I will not focus on data backup and recovery. If you wish to backup your data, you can do so. After installation of your operating system you can restore the data from backup.
Install fresh operating system
This method is the easiest and I would say least problematic. This will format(wipe) your hard drive and install a clean operating system. No files will be saved or transferred in this method. So be sure to backup any important data you wish to save as it will be deleted during this method.
1)You will need the operating system media. The operating system you wish to install can be on a DVD or USB flash drive for example.
2)Insert the media and reboot the computer.
3)As the computer is booting up, you will see some options come up during the boot process(very briefly). One of these options will be for your BIOS. It may say press f11 for bios, or DEL for settings. What we want to do is go into the computer BIOS and change the boot order.
4) Once in the BIOS, change your boot order so the operating system media is booted first. For example, if you have your new operating system on a USB flash drive, then you want to make sure the USB flash drive is first in the boot order list.
5)Once you make the boot order changes, exit out of BIOS saving your settings. When your computer reboots again it will boot to the media you selected.
6)Depending on what operating system you had installed before, you may get different options. You may get options to perform a recovery and or to just do a fresh install. We want to make sure you do a fresh install. This will format(wipe) the hard drive and install the operating system you wish to use. The hard drive will be formatted and the operating system installed. Once installed, you will go over settings basic computer settings like language, time, computer name and internet connectivity. This varies depending on the operating system you are using. Be sure to follow the on screen prompts.
If you installed Windows 7 over an older version of Windows
In this method you can revert Windows 7 to a previous version of Windows. The Windows 7 installation will have created a Windows.old folder that contains your previous operating system and personal files. This Windows.old folder is in the root of the Windows partition. Reverting does not keep any current files or settings so beware. Your computer will be reverted to its previous state before Windows 7 was installed.
The following tech article from Microsoft will go over the process to revert Windows 7 to a previous version of Windows that was installed.
http://support.microsoft.com/kb/971760
The following tech article from Microsoft will go over how to do this process with Windows XP.
http://support.microsoft.com/kb/303661
Wipe hard drive securely
If you want to truly erase data you will need to use software utilities to do this. Deleting data on your computer or reformatting your hard drive will not completely erase the data. There are numerous software programs out there you can use, free and costly.
A free tool you can use to erase your hard drive is KillDisk. You can click the link below to visit the site and download the software.
http://www.killdisk.com/downloadfree.htm
I hope my article was informative. Be sure to check out my other Tips and Tricks by clicking on my profile name and then clicking on "Tips" at the top left of my profile.
Regards
G33k
Keywords
How to remove windows, how to delete windows, delete windows, remove windows, how to remove Microsoft Windows, How to delete Microsoft Windows, how to remove Windows 7, how to delete Windows 7, how to revert Windows, how to install new operating system, how to delete operating system
Computers & Internet Logo
Unable to install yahoo messenger error 0xc0150002
First, do an PC search in drive c, type in Yahoo Messenger, Search delete the folders. Reboot your computer for a Clean Install of the Y!M 10.Many have problems with the new Y!M 10, in windows XP and Vista and are reverting to a previous version more compatible with their operating system.
Here is the safe valid link to download your previous version:
http://www.oldversion.com/Yahoo-Messenger.html
Apr 28, 2011 | Yahoo Messenger
hi my pc up graded to explorer 9 when my daughter was using it how do l get back to explorer 8 l have windows 7
To uninstall Internet Explorer
The following instructions apply to both Windows 7 and Windows Vista.
  1. Click the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.jpg, type Programs and Features in the search box, and then click View installed updates in the left pane.
  2. Under Uninstall an update, scroll down to the Microsoft Windows section.
  3. Right-click Windows Internet Explorer 9, click Uninstall, and then, when prompted, click Yes.
  4. Click one of the following:
    • Restart now (to finish the process of uninstalling Internet Explorer 9, and restore the previous version of Internet Explorer).
    • Restart later (to wait until you shut down or restart your computer).
Note
After you uninstall Internet Explorer 9 RC, the previously installed version of Internet Explorer will be available on your computer. It is not necessary to reinstall.
Mar 12, 2011 | Computers & Internet
eRROR 1406 CANNOT OPEN MICROSOFT EXCEL
Method 1Set the permission for the Everyone group of the registry subkeys that are listed in the error message to Full Control. Use the 'Fix It' and follow the steps provided in the KB article
For more information how to let Microsoft Fix it for you , click the following article number to view the article in the Microsoft Knowledge Base: 313222 How do I restore security settings to the default settings? Method 2Disable the third-party application. For example, to disable WebRoot Spysweeper, follow these steps:
  1. Right-click the WebRoot Spysweeper icon that is located in the notification area, at the far right of the taskbar.
  2. Left-click the Shut Down option.
  3. In the Office installation Error 1406 dialog box, click Retry.
  4. When the Office setup is completed, restart the computer, and then re-enable WebRoot Spysweeper.
Method 3Take the system into a "clean boot" state, and then run Office setup. This disables the third-party applications. The third-party application that is denying access to the registry subkey can no longer deny access.
For more information about how to take the system into a "clean boot" state, click the following article number to view the article in the Microsoft Knowledge Base: 310353 How to configure Windows XP to start in a "clean boot" state
For more information about how to take the system into a "clean boot" state, click the following article number to view the article in the Microsoft Knowledge Base: 950093 How to use the System Configuration utility to troubleshoot configuration errors in Windows Vista
The third-party products that this article discusses are manufactured by companies that are independent of Microsoft. Microsoft makes no warranty, implied or otherwise, about the performance or reliability of these products. Method 4Some activation problems indicate that the license file is corrupted. If the license file is corrupted, you cannot resolve the problem by removing and then reinstalling the Office product. The license file is not removed when you remove the Office product. Additionally, the license file is not overwritten when you reinstall the Office product. If the license file is corrupted, use one of the following methods to delete the license file.
Note Method 4 applies only to Office 2007, Office 2003 and Office XP. Office 2010 does not use the OPA licensing file.
Feb 01, 2011 | Microsoft Office 2007 Full Version...
fatal error when installing hp scanjet g3110 software
The error may occur if there is a new version of Solution Center or a component of the scanning software has already been installed due to a software update or due to incomplete uninstallation.
b9ebeb2.jpg Solution To resolve the issue, complete the following steps:
  1. Run the uninstaller from the CD.
  2. Run all four levels of uninstallation from the CD. Browse the CD to the Utils folder and then the CCC folder, where you could find:
    • uninstall_L1.Bat
    • uninstall_L2.bat
    • Uninstall_L3.bat
    • Uninstall_L4.bat
    Run these files, and follow the instructions. Most of the fatal errors that occur due to the incomplete uninstallation should get resolved after the four levels of uninstallation are done. However, if there is a new version of the software that has been installed, then continue with the next step.
  3. Download Microsoft Windows CleanUp Utility from Microsoft Knowledge Base Article 290301, Description of the Windows Installer CleanUp Utility . Click here to go to Microsoft Knowledge Base Article 290301 (http://support.microsoft.com/kb/290301) .
  4. Open Windows CleanUp Utility, scroll down the list, check for the HP Scanjet related entries and remove them. Entries that need to be removed:
    • Bufferchm
    • DocProc
    • Esupport Q-folder
    • Scan
    • Solution center
    • WebReg
    NOTE: Some entries are common for both earlier and newer versions of Solution Center and bear common names. Deleting these entries may result in the other versions of Solution Center not working.It is advisable to install the older version of the software first, and then the newer version. 2d75964.jpg
Restart the computer and try reinstalling the software. This should resolve the issue
Oct 22, 2009 | HP ScanJet 4100C Flatbed Scanner
install XP, it hangs up with the message at the bottom ''Searching for previous versions of Microsoft Windows'' please help
You already have a previous xp on our computer. You need to first go to your control panel, then install or remove programs and delete the old xp, then reboot computer, now reinstall xp with new software.
Oct 18, 2009 | Microsoft Windows XP Professional with...
638 people viewed this tip
David Payne
David Payne
