Tip & How-To about Car Audio & Video
If your stereo looses the memorized stations
Try to "cross" the suply red and yellow cable on the ISO group of cables behing the stereo. It should solve the problem of memory loss. Take care with conexions, read the manual first.
If the stereo gets to hot even when it is off, the problem can also be a bad conexion and you could solve it by crossing red and yellow cables. Refer to your manual.
Car Audio & Video Logo
Is it normal during the installation of the H&B CA-8050 CD player it gets hot after working 15 minutes?
If the stereo gets to hot even when it is off, the problem can be a bad conexion and you could solve it by crossing red and yellow cables. eject the radio, check your iso connector, you can tray to cut both cables and connect them again the red to the yellow and vice versa. Refer to your manual for further information on conexions. Check also that the stereo is keeping the values you give (radio station memorys, bass - treble adjustments, etc) If the conexions are wrong, the radio doesn´t keep these values when you take the ignition key off.
Sep 05, 2010 | H&B CA-8050BT CD Player
how to take of steering wheel in audi 80
First you have to disarm SRS system.How- ensure ignition switched OFF.Remove ign.key.Disconect battery earth lead and make sure accidental reconection is not possible.Disconect power suply multi-plug/red/,located behing driver.s storige compartment under fascia.No waiting time required. Now you have to remove driver.s airbag.There is two screws with 5mm allan/hexagon/head behing an airbag.Open it.Disconect and remove airbag.Use 24 socket for steering wheel nut. When remove a steering wheel be very carefull with spiral cable behing.GOOD LUCK !!! There is tightening torque for steering wheel nut-40Nm and two screws-6Nm.
Apr 24, 2010 | 1991 Audi 80
How do i change form radio to Cd or ipod
Do you have the problem since the moment you instaled the stereo. I´m not sure, but it is possible that you have done a wrong conexion. In some cars (ford, opel, etc) it is necessary to cross red and yellow cable in the iso connector in order to get the correct operation of all funtions. I had to do this in my ford focus, but I do not warrant that it'll work with your stereo. You may also ask your dealer about the original power suply conexion so you don´t burn a fuse on a wrong conexion trial. Hope it helps.
May 18, 2008 | H&B CA-8050BT CD Player
doesn't keep memory
DIKA, first step - check your stereo batt backup wire , you must connect that direct or continues voltage from accu. Don't switch this wire, you can check if your car in off position , this  wire must still have voltage +12v - +14v if no voltage check your fuse near batt backup wire. Why that wire must have voltage,that's because the voltage used for backup your stereo memori. OK good Try , Fixya and Don't forget to vote me, thank's
Aug 21, 2007 | JVC KD-G420 CD Player
1,330 people viewed this tip
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
