Tip & How-To about Electronics - Others
Backing up your computer is recommended if the data you keep on your computer is to important to lose. I will go over some tips and tricks on backing up your PC data.
Recommended Storage Devices
I recommend you use USB mass storage devices for backing up and retaining data. A good example of a mass storage device commonly used for data backups is external USB hard drives. I personally like Western Digital USB hard drives but there are many out there to choose from. You can take a look at some examples by visiting www.newegg.com. You can get 1TB drives very cheap and the prices continue to drop.
You can use other types of storage like USB flash drives, DVDs and even other computers. USB flash drives and external hard drives are cheap, easy to use and small, making them excellent storage devices.
It is recommended that you store data off of the computer who's data you are backing up. Why? If the computer is damaged, this can potentially ruin your backup and you lose the data. You want to move the data off the computer to reduce the number of failure points. For data that is even more critical to you, you can create additional backup copies so if one backup storage device fails, you have a copy of this. This process is called mirroring.
Backup Software
There are different ways to actually back up the data. You can do this manually or use software. I recommend using software to simplify the process. There are also numerous backup software utilities out there, some free and some costly. A popular free backup tool for average computer users is EASEUS Todo Backup and click here for the user guide. This tool is very easy to use.
An example of backing up data manually would be to click and drag the data like videos or images to a storage device. If you have a lot of data, this can be time consuming.
Backup Process
The backup process is simple and straightforward when using a USB storage device and back up software.
-Download and install your backup software tool.
-Plug in your storage device.
-Make sure your computer recognizes your storage device. Most devices are plug and play so once you plug it in, it should install device drivers and be ready to use.
-Run EASEUS Todo Backup software and click Backup to start the process or reference user guide for software you are using.
-Once your backup is done, you can store the storage device in a safe place.
What is the best backup method for me?
There are different
types of backup methods and each have different pro's and con's so I advise to read
up on backup methods and choose the best one that fits your needs.
You can click here to read about Differential vs Incremental backups. Either one will ultimately accomplish a backup which is what our end goal is.
General Tips
-After your initial backup I recommend you schedule backups to continuously keep your data up to date.
-Use USB storage devices like external hard drives and flash drives. They are cheap and small in size, big in storage space(GBs).
-Use backup software to simplify the backup process.
I hope this article was informative. Be sure to check out my other tech articles by clicking on my profile name and then going to "Tips" at the top left of my profile.
Regards,
G33k
Keywords
back up pc, back up computer, back up data, how to back up data, how to back up pc, how to back up computer, back up tips, storing data, protecting computer
That can be frustrating :( hope my solution below helps..
based
on the current situation, I suggest trying the following steps: restart
the computer and keep pressing F8; Use Last Known Good Configuration.
If
the issue still occurs after that, I suggest testing if we can boot
from a Windows disk. If so, please install Windows on another
partition and access your important data. After backing up those data,
you can use Windows disk to format the drive and reinstall Windows.
However, if we cannot boot from a Windows disk, the issue can be caused by incorrect BIOS settings or damaged hardware. I recommend contacting your computer manufacturer to check BIOS and hardware.
May 26, 2011 | Computers & Internet
Sep 08, 2017 | Cavalry Storage Cavalry CADB001U32 1TB...
Nov 07, 2010 | Computers & Internet
Jun 10, 2009 | Fanner MASSCOOL 3.5" PATA and SATA hard...
2,620 people viewed this tip
