Tip & How-To about Nintendo Wii Console
Nintendo Wii Error Code 51330 usually indicates that the WEP/WPA key you set on your Wii is not the correct one to gain access to your router. When you setup a router for wireless internet, you usually set a WEP key or by default one is set. This is basically a security key(password) that you set so any device that wants to use your internet has to enter correctly in order to gain access. If you know your router security key, go into your Wii network settings and make sure it is entered correctly. Click here to read my tech article on how to configure your Wii's network settings. If you do not know the security key of your router, then read my other article by clicking here. This article will go over how to find the router security key or if need be, set one. Be sure to check out my other Tips by clicking on my profile name and then clicking "Tips" at the top left. Regards, G33k KeywordsNintendo Wii Error Code 51330, error 51330, Wii 51330, Wii error 51330, Wii network settings, can't connect Wii to netflix, Wii netflix, Nintendo error code 51330, Wii code 51330
Nintendo Wii Console Logo
I have been trying to connect my Wii to my Linksys wireless in my home and every time I try, I get the error code of 51330 with a mention of being unable to connect to the internet. What can I do to fix this issue? Thanks
A. Do you have the SSID for your Linksys router as just "linksys"? That name is so common that someone nearby might have set up a new router and left it the same name as well... and your Wii is trying to connect to THEIR "linksys" instead of yours. Try changing the name broadcast by your router to something else, then try connecting using that new name.
B. Be sure you are typing in the WEP or WPA passphrase correctly, it is SO easy to mess up one simple letter in the code and nothing will work. I've gotten dozens of service calls for iPods and games where the customer said their code didn't work, but worked for me when I got there. I know, it's frustrating, just be SURE you have the code 100% correct.
Other reading material from Nintendo is below:
Wii error code 51330 It is unlikely that your Wii console needs any type of repair, as according to the Nintendo Error Code Lookup, the 51330 error code is "usually indicates a problem relating to wireless security."
Error Code: 51330 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
  3. Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available).
  4. Check Nintendo's router info for special notes, if available, for your router.
    1. Click here to go to our Wireless Router lookup page.
    2. Use the drop-down box to select, if available, your router manufacturer.
    3. Click on your router's model number, if available.
    4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
  5. Ensure that the router is set to broadcast in "mixed" or "b/g" mode. Routers set to "g only" may not be able to allow a successful connection from the Wii console. (The option to change this setting is typically found in the "Wireless" section of your router's settings. For information on accessing your router's settings, click here to select the brand name and model number of your router, if available.)
  6. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
  7. Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
  8. If you are still receiving this error code, please click here for assistance.
But if the above information doesn't help correct this problem, then give a call to Nintendo's 1-800-255-3700 (6 am ~ 7 pm Pacific, everyday) Customer Service number, and one of the service representatives will do some over the phone troubleshooting to determine exactly what is causing this and then talk you through any needed steps to correct it.
May 25, 2011 | Computers & Internet
Hello, I'm trying to connect my wii wireless and it keeps giving me an error code 51330 "unable to connect to the Internet" could you tell me what it means? Thank you.
Error Code: 51330
  • Log into the router using the default IP (consult your router's manual for assistance)
  • Locate the "wireless security" section of your router settings and find the WEP or WPA key.
  • If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
  • If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
  • The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
  • If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
  • If you are using WPA, the Wii console is compatible with the following types:
  1. WPA - PSK (TKIP)
  2. WPA - PSK (AES)
  3. WPA2 - PSK (AES)
Feb 27, 2011 | Nintendo Wii Console
error code 51330 on the wii.it will not except my
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
Need further troubleshooting? Go straight to Nintendo's website at:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US
Nov 19, 2009 | Nintendo Wii Console
cannot connect to internet error code 51330 is showing
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
Need more info? Check Nintendo's website at:
3,864 people viewed this tip
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
