Tip & How-To about Sony Alpha DSLR-A580 Body Only Digital Camera
Upload WebM Videos to YouTube-Convert TM90 AVCHD MTS to WebM format for Youtube
Best MTS to Youtube Converter-Convert Panasonic MTS to WebM for Uploading on Youtube
Cut/Merge and Convert Panasonic TM90 MTS to WebM for Youtube
Convert/Upload Panasonic HDC-TM90 AVCHD MTS to WebM Video for Youtube
I have a Panasonic Camcorder, HDC-TM90, which produces .mts files with 1920*1080p. I record some more mts videos by tm90 and want to upload to youtube for sharing with my friends. But YouTube does no support AVCHD files yet. One of the fast solutions is to convert 1080p AVCHD videos to Youtube support format, then upload the video to YouTube. Now when you upload video to Youtube, Youtube will be cutomatically converted the video to webm format. So for solve this problem, I recommend use Aunsoft Final Mate as the Upload WebM Videos to YouTube.
WebM is an audio-video format designed to provide a royalty-free, open video compression format for use with HTML5 video. The project's development is sponsored by Google. A WebM file consists of VP8 video and Vorbis audio streams, in a container based on a profile of Matroska.
Below is the fast guide for you to convert AVCHD files from Panasonic HDC-TM90 camcorder to .webm videos for uploading to Youtube on Windows 7.( It also works .mts files on Windows XP, Windows Vista.)
Step 1. Capture .mts files from Panasonic HDC-TM90 to Aunsoft Final Mate.
Connect your Panasonic HDC-TM90 MTS camcorder to pc computer with USB cable. Then launch Final Mate as the Best MTS to WebM Converter With smart camcorder wizard included in Final Mate, you can easily capture MTS files from camcorder to hard drive or to the program for basic editing.
Tip: by clicking on Browser button "Add" from Resource Tab on the main interface of Final Mate to browser for MTS file folder, you can also add MTS files from computer to the program.
Step 2: Create a Movie for Cut and Merge Panasonic HDC-TM90 MTS files for Youtube WebM.
Click the Add movie button, and choose the" For Conversion", a movie about cut mts for conversion output will be created by default. You can also create multiple movie for split .mts files.The Final Mate can output multiple for cutting mts files with WebM.
Step 3: Add .mts files for split/delete redundant clips for youtube.
Select the MTS files you would like to cut mts from the Camcorder/Resource tab, drag and drop to the movie.
Step 4: Splitting meaningless .mts Clips on Timeline for upload on Youtube.
From the timeline, you may notice the vernier, which is used as time pointer. Click on the Vernier, and move to the timeline you want to cut, and click the "Split" button to cut the video. You may also click the Split button when the video plays to the point you want to cut.
Then click on segment you want to cut off from the timeline, and then click the" Delete" button next to the Split button to remove the unwanted .mts clips.
Step 5. Convert MTS to WebM format for Youtube.
Click the Export button, and go to the last tab. Choose Common Video > WebM Video Format(*.webm) as output format. Then click the OK button, and the Youtube WebM video converter will convert Panasonic HDC-TM90 MTS files to WebM files for Youtube on Windows .
When the conversion is done, you can upload the video to Youtube with WebM codec.
Tips: If you are running Mac OS X like Leopard or Snow Leopard, just try Aunsoft Final Mate for Mac as AVCHD video management tool on Mac.
Sony Alpha DSLR-A580 Body Only Digital Camera Logo
Sony HDR-SR10E,Share Sony HDR-SR10E MTS to FLV for Mac Users Do you have some short films shot with Sony HDR-SR10E AVCHD camcorder, and want to share them on your website? It will make your site more attractive with videos. While Apple compete with Adobe, the Flash support on Apple devices like iMac, MacBook Pro do not support exporting to Flash FLV/SWF now. You can not directly export FLV from the Apple QuickTime Player, iMovie or Final Cut Pro/Final Cut Express. One solution is to upload videos to YouTube and embed YouTube videos on your site. If you do not want to embed YouTube videos, you can convert Sony HDR-SR10E MTS files to FLV with Mac Sony MTS converter, and put the FLV videos on web server with Flash player. Aunsoft MTS/M2TS Converter for Mac is the recommended Mac Sony HDR-SR10E MTS converter for you. It exports Flash videos with automatic deinterlacing function, which makes the FLV videos play without interlacing artifacts. It could also help you merge several Sony .mts video clips and export as one file. Here is the step-by-step guide to convert Sony HDR-SR10 videos to Flash on Mac. Step 1. Load Sony HDR-SR10E videos to Aunsoft MTS/M2TS Converter for Mac. Run Aunsoft MTS/M2TS Converter for Mac as the Mac Sony HDR-SR10 converter, and click the "Add" button to load .mts files for conversion. Step 2. Choose Flash FLV output format. Click the "Format" option, and choose Flash Video > FLV-Flash Video Format(*.flv) as output format. You can also choose the profiles like FLV H.264(*.flv) or F4V(/f4v). Tips: With The above mentioned output, you shall use Flash player like JW player, Moyea PlayerBox player, or Flow player to play the Flash videos. If you want the video to play automatically, you may choose SWF-SWF Forma(*.flv) as output. Step 3. Transcode Sony HDR-SR10 MTS to Flash. Click the "Convert" button under the preview window, and the conversion from Sony MTS to Flash video FLV/SWF will start right away. Wait for a while, and you can upload the Flash videos to your sever and embed them on your web page. PS: 1. The "Merge into one file" on the main interface is to join/splice .mts files. 2. If you are using camcorders like Sony HDR-CX350, HDR-XR520, HDR-TG7, or Cyber-shot DSC-TX7, DSC-H5V, you can also use the Mac Sony MTS converter to export FLV files for web sharing. Aunsoft MTS/M2TS Converter for Mac also works with Canon HF S21, Canon HF100, Panasonic HDC-TM700 and other AVCHD camcorders.
You may use Nidesoft Sony XPeria Video Converter.It is excellent Movie Converter tool for the new released XPERIA X1. Sony's XPERIA is a hiptop killer that has a touch UI, but a Hiptop-esque slide keyboard. A Windows Mobile device, the X1 features full QWERTY, a 3.2MP camera, 3-inch touchscreen at 800 X 480 resolution, Wi-Fi, 400 MB of internal storage and microSD support.
http://www.nidesoft.com/sony-xperia-video-converter.html
Jul 22, 2010 | Cameras
1,313 people viewed this tip
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
