Tip & How-To about Office Equipment & Supplies
How to get the page count on a Ricoh Aficio copier
On Ricoh's Aficio line of copiers, you can get the page count without having to print out a configuration page or status page. To see the page count of an Aficio copier, follow the steps below.
For models with touch screens:
With the copier turned on, press the User Tools/Counter button on the operation panel. (If User Tools and Counter are two separate buttons on the model you are using, press the Counter button, and the page count will be displayed -- that's all there is to it.) When the User Tools menu appears on the screen, press the Counter button on-screen (typically located in the lower left or lower right corner).
The copier's page count will be displayed on the screen. For copiers with additional functions (such as printing) the page count will also be broken down by function. Color copiers will display a color page count and a black and white page count, but not a total count.
You can print out a hard copy of the page count if you want it for your records, or to fax somewhere. To print the counter, press the Print button on the screen, then press the Start button (on the right side of the operation panel).
For models without a touch screen:
With the copier turned on, press the User Tools/Counter button on the operation panel (typically located just to the left or right of the display screen). The User Tools options will appear. If Counter is the highlighted option, press the OK button to select it; otherwise, use the arrow buttons to select Counter, then press OK.
The counter will be displayed on screen, but you can print it out by pressing the selection button below where Print is displayed, then pressing Start.
How can I check the color counter page for Ricoh Aficio SP C210SF?
The instructions for getting the page count for the C210SF should be the same as for the C231SF:
- Press User Tools.
- Scroll down until you see Reports Print.
- Press OK.
- Scroll down to either Configuration Page (2 pages long, prints in black and white) or Maintenance Page (1 page long, prints in color).
- Press OK.
Both the configuration page and the maintenance page will show the page counts. For page count instructions on other models of copiers or printers, check out ConfigPages.Blogspot.com.
Aug 11, 2011 | Ricoh Aficio™ SP-C210SF Printer
How do I get a meter read off this printer? Ricoh SPC410
Print the configuration page. Print count is on there.
Jul 29, 2011 | Ricoh Aficio SP C410DN Laser Printer
need to know how to get a page count from an ricoh aficio 1022. i hear you can get it from the config page but how do i print out a config page? help!
Press the usertools key then select counter on the display. You will then see the counts. You can also print the counts from this screen by pressing print on the display screen then press the print button.
Jun 30, 2010 | Ricoh Aficio 1022 All-In-One Laser Printer
how do you get the page count on a aficio mp 3500
Print a configuration page and it will give you the total page count.
Nov 26, 2009 | Ricoh Aficio CL2000N Laser Printer
3,269 people viewed this tip
k24674
jasbo
jasbo
