Tip & How-To about Garden
Basic lawnmower spring maintenance
Before it gets too late its worth firing up the lawnmower (and any other garden power tools) to make sure they are running well for the coming months. Here are a few basic tips to make sure it will be worry free for the summer.
Give it gas: fill it up with fresh quality gasoline (mixed properly with fresh oil if its a 2 stroke). Old gas is not the same as new gas, volatile compounds will evaporate over time leaving you with gas that is harder to burn. Ideally you have used up everything in the tank the previous fall.
Let it breathe: make sure the air filter is clean. For foam filters you can just clean them with a bit of gasoline (you can use the old stuff if you still have some). Paper filters need to be replaced, typically every year.
Light the fire: a strong spark is the key to reliable ignition. If the first two tips don't give good results its probably time to change the spark plug.
Garden Logo
My Garden line ,Aldi lawnmower isnt running well. It is smoking, running slowly,back firing and, using lots of fuel.I have changed the oil and the fuel to no effect. can you help?
if it isnt the spark plug
is this the same aldi mower
Gardening with Rik unboxing and review of the Gardenline Aldi lawnmower
how much work has it done
did you tip the mower over the wrong way and oil got into the valve cover or carby
the carby is a metal bowl with a 10 mm drain nut
undo that see if fuel is clean and flowing
best bet is it needs a carby clean or throttle cable adjustment
maybe even a govenor adjustment
Mar 26, 2017 | Garden
Hi the blades on my E-drive 1200w lawnmower are not turning?
Sounds like you have lost or broken your shear pin out of your drive pulley. Make sure your drive belt is working the way it should be. You did not say if its working.
Mar 19, 2015 | Garden
trouble starting Murray 5.o lawnmower
Check for spark. Is the plug fouled? Have you hit anything lately with the blade?
Jul 19, 2013 | Garden
lawnmower is firing but won't start
check to see if the valve is stuck open do a compression test
Apr 27, 2012 | Garden
lawnmower will not move in gear with motor running
Hi
Check to see if any oil leaks between rear wheels where the tractor was parked. Also make sure hydrostatic disengage lever, at rear of tractor by hitch, has to be pushed in.
Apr 05, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
846 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
john h
