Tip & How-To about Sony Alpha DSLR-A580 Body Only Digital Camera
EOS Converter-Transcode Canon DSLR 550D Video to ProRes 422 in Full HD 1080p for FCP editing
Convert/Import Canon Rebel T2i/550D 1080/30fps H.264 MOV to ProRes 422 Codec for FCP 6/7
Canon EOS Digital Rebel T2i / 550D recorded videos are saved in H.264 for image and linear PCM for audio. You can choose different recording modes like full HD 1920×1080p at 30/25/24 fps, HD/SD 1280×720p/640×480 at 60/50 fps. Even though the videos are saved in .mov format, you may also face problem importing the video to Final Cut Pro. So you need a Mac Canon EOS Video Converter for converting and importing 550D1080p MOV for Final Cut Pro without rendering. Aunsoft Video Converter for Mac is the recommended Mac Canon EOS Converter for you to edit Digital Rebel T2i / 550D videos.
Below is the quick guide for those who have a hard time editing Canon EOS Digital Rebel T2i / 550D H.264 MOV files to ProRes 422 at 30fps in Final Cut Pro 6 or 7.
Step 1. Download Canon 550D MOV files to Aunsoft Video Converter for Mac.
Run Aunsoft Video Converter for Mac as the best Canon EOS Rebel T2i H.264 MOV to ProRes MOV converter on Mac OS X. Click the "Add" button to import .mov files from the camera.
Step 2. Choose MOV format with ProRes 422.
Click the "Format" option, and navigate to Final Cut Pro > Apple ProRes 422 (*.mov) as output format. The Mac Digital SLR camera video converter will convert H.264 mov to prores 422 mov.
You may notice that there are also other options like Apple ProRes 4444, Apple ProRes 422 (HQ), Apple ProRes 422 (LT), Apple ProRes 422 (Proxy), DVCPRO HD 1920*1080 30fps etc.
Step 3. Choose 1080p size with 30fps.
Click the "Settings" button and choose 1920*1080 from the video size drop-down box to keep the original HD resolution and 16:9 aspect ratio. Click the drop-down box for frame rate, and you can choose 30fps.
Step 4. Convert DSLR video to ProRes 422 HQ MOV for FCP.
Click the convert button under the preview window, the Mac Canon 550D DSLR video converter will start converting DSLR video to ProRes 422 in full HD 1080p for FCP editing.
After the conversion, you can import ProRes mov to Final Cut Pro without rendering.Hope you enjoy the optimal way to convert Canon H.264 mov to ProRes 422 for FCP 7 and 6, so that you can edit the H.264 files easily.
Sony Alpha DSLR-A580 Body Only Digital Camera Logo
Does Nikon D7000 MOV workable in FCP 6?
MOV format with Prores codec is FCP 6preferred video. So a program which has prores codec output is greatly helpful.As far as I know, two apps can export Prores codec video. One is Clipwrap andanother is Video Converter released by Pavtube. Clipwrap can not achieve yourtask because it only supports AVCHD videos. So please test Pavtube VideoConverter to check if it is helpful. It provides free trial version in Pavtubesite.http://www.pavtube.com/video-converter-mac/
Jun 11, 2012 | Cameras
1,270 people viewed this tip
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
