Tip & How-To about Sharp FO 5700 Plain Paper Laser Fax
How to get the page count for a Sharp FO-5700 fax machine
Sharp makes a line of fax machines, one of which is the FO-5700. The FO-5700 is easy to maintain and to use, and it can run well for years. If you want to view the life counter (page count) for your FO-5700, just follow the steps below.
With the fax machine on and ready, flip up the bar that displays the information for half of the quick dial buttons (#17-32). This bar has a tab that you can use to flip it, which sits right by the panel release lever (where you would put your hand to raise the operation panel if you had to remove a paper jam there). Just flip this bar up so that it covers the first half of the numbers instead of the second.
Once the bar is flipped up, you'll see that the V button is labeled "Life." Press that button to bring up the counter menu. Then press 1 on the fax machine's number pad. The screen will display "1: Life Counter" and below that, "LIFE=xxxxxx" where "xxxxxx" is the page count of the machine, in six-digit format.
You can view this life counter at any time, without having to print out a configuration page or usage page. To exit out of the life counter screen and return to the main screen, press the red Stop button. Be sure to flip the contacts bar back to its original position; there is a sensor that detects which way the bar is laying, and if it's still in the up position, pressing a button will have a different effect than it would if the bar were in its original position (such as bringing up the life counter instead of dialing a number).
Sharp FO 5700 Plain Paper Laser Fax Logo
Sharp FO-4700 Fax Not Received Even Though OK Fax Confirm Given
It's gone forever, once your machine received a EOT (end of transmission signal), your fax machine thinks it was received OK and clears it from memory.
Oct 28, 2009 | Sharp FO 5700 Plain Paper Laser Fax
sharp fo 4700 display error ( polygon )
You have a bad printhead unit(laser unit) . The polygon mirror is not rotating within a specific amount of time. I recommend you to replace your fax unless your willing to spend between 200 to 500 dollars.
May 03, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Sharp FO5700
I have never seen this error code on a sharp FO 5700 are you sure that is the right model # or error code. I even did a search in the FO5700 service manual(no luck). I believe I have seen this code before on a sharp copier.
Sep 05, 2008 | Sharp FO 5700 Plain Paper Laser Fax
Message that tray is out of paper, and tray is not in machine.(SHARP FO-5700 Fax)
Go underneath the machine and make sure that a black piece of plastic is secured in there. Sometimes they get pulled out when the tray gets removed.
Jul 01, 2008 | Sharp FO 5700 Plain Paper Laser Fax
1,782 people viewed this tip
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
