Tip & How-To about Sony Alpha DSLR-A580 Body Only Digital Camera
Transcode/Convert AVCHD MTS/M2TS Video to FCP Apple ProRes 422 without rendering on Mac
Apple ProRes 422 is a standard-definition and high-definition lossy video compression format developed by Apple Inc. for use in post production. It was introduced in 2007 with Final Cut Studio 2 and is comparable to Avid's DNxHD codec which has the same purpose and uses similar bit rates. Both are DCT basedintra-frame-only codecs, and are therefore simpler to decode than distribution oriented formats like H.264. FCP/FCP7 is Mac based editing software which supports transcoding AVCHD MTS/M2TS to Apple ProRes for further editing.
AVCHD MTS/M2TS files produced by HD camcorder like Panasonic HDC-TM700, HDC-HS700, HDC-SD700/SD600, Sony CX350, Sony CX550, Canon HF200, etc are not the preferred formats by FCP/FCP7. Even you will have problem for transferring and logging these MTS, M2TS videos.
So the program you need is a great Mac MTS Video to Apple ProRes 422 Converter. With it, you can convert any HD camcorder 1080 60p/50p, 1080i AVCHD (*.mts, *.m2ts), 720p AVCHD lite files to Apple ProRes 422 for editing with Final Cut Pro, Final Cut Pro 7 on Mac.
Below is the step-by-step guide for you to quickly Transcode/Import AVCHD to FCP Apple ProRes 422 Codec (*.mov) for editing.
Step 1. Download MTS/M2TS files to Apple computer.
Connect your AVCHD camcorder c to Apple computer via USB cable, find the .mts, *.m2ts files from the camera folder like PRIVATE > AVCHD > BDMV > STREAM. Then copy and transfer the .mts, *.m2ts files from camera to the Apple hard drive disk.
Step 2. Import MTS/M2TS files to Aunsoft Video Converter for Mac.
Run Aunsoft Video Converter for Mac as the best AVCHD to FCP Apple ProRes Converting software, and click the "Add" button to load AVCHD .mts or .m2ts videos. You may also directly drag and drop the AVCHD video to application UI for importing files.
Step 3. Choose Final Cut Pro-Apple ProRes (*.mov) output format.
Click the "Format" option and navigate the mouse cursor to Final Cut Pro > Apple ProRes 422 (*.mov) as output format. The Mac MTS/M2TS Video to FCP Converter will convert AVCHD to Apple ProRes 422 MOV with high quality. (Tip: The Apple ProRes (*.mov), DVCPROHD (*.mov), HDV (*.mov) formats under Final Cut Pro output profile are available when your FCP is installed on Mac).
Step 4. Convert AVCHD MTS/M2TS video to Apple ProRes (*.MOV) for Final Cut Pro.
Click the convert button under the preview window, and the Mac MTS/M2TS to FCP Converter will start the conversion from AVCHD to Apple ProRes MOV for Final Cut.
After the conversion, you can easily import Apple Prores 422 to Final Cut Pro without rendering for editing.
Tips:
If you would like to edit AVCHD MTS/M2TS with FCE/iMovie, Avid, etc, you can convert MTS/M2TS to Mac itself bring format like Apple Intermediate Codec, DV PAL/NTSC, DVCPRO NTSC/PAL, DVCPRO50 PAL/NTSC (*.MOV) for FCE and iMovie, or transcode MTS/M2TS to Avid DNxHD (*.mov) for Avid on Mac.
Sony Alpha DSLR-A580 Body Only Digital Camera Logo
Best Mac MXF File Converter-Import/Edit Canon MXF Files to ProRes 422 MOV to FCP MXF file format comes from like Panasonic HVX200/HPX300, Canon XF300/XF305, Sony EX camera, etc. It is not compatible with many programs just like Apple Final Cut Pro. So Convert MXF file to FCP MOV Video is a necessary step to do if you want watch your video from your camcorder which export mxf file. And we know that Apple ProRes 422 , Apple ProRes 4444,introduced in Final Cut Studio, was advertised to one of the codecs to result in less compression and higher data rate/higher quality files for HD editing in Final Cut Pro. Below is the step-by-step guide for you to quickly Convert/Edit MXF to Apple ProRes 422 (*.mov) Final Cut Pro on Final Cut Studio,Final Cut Pro 7 on Mac. Step 1. Add MXF videos to Aunsoft MXF Video Converter for Mac. Connect your MXF Camcorder to iMac with USB 2.0 cable or use card reader to transfer the .mxf files to Apple hard drive disk. Run Aunsoft Video Converter for Mac as the best Mac MXF to FCP Apple ProRes Converter . and click the "Add" button to load .mxf videos. Step 2. Choose Apple ProRes codec for Final Cut Pro. Click the "Format" option, choose the Final Cut Pro > Apple ProRes 422 (*.mov) and navigate to the Final Cut Pro group, you will notice that there are profiles with Apple ProRes 422, Apple ProRes 422(HQ), Apple ProRes 422(LT), Apple ProRes 422(Proxy), Apple ProRes 4444. Here we choose Apple ProRes 422(HQ) (*.mov) as output format. (The Apple ProRes 422 (Proxy) codec is intended for offline editing and contains 30 percent of the data rate of Apple ProRes 422, and I recommend you to select Apple ProRes 422(HQ), Apple ProRes 422(LT) MOV for outputting.) Step 3. Merge Canon MXF files. (Optional) Tick the checkbox for "Merge into one file", and the Mac MXF Video Converter will join and combine the video clips into a single file as output. Step 4. Convert MXF to Apple ProRes MOV for Final Cut. Click the convert button under the preview window, the Mac MXF Video converter starts converting MXF videos to Apple ProRes MOV, and joining the MXF files for editing in Final Cut Studio. After Converting and Merging the MXF files, just import the output Apple PreRes 422 .mov files to Final Cut Pro 7 or Final Cut Pro 6 for editing and the video .Optimize your workflow and save time with the Apple ProRes compression for Final Cut Pro. You can also import the output videos to Final Cut Express (FCE) 4 for editing in full HD.
Jul 13, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
1,209 people viewed this tip
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
