Tip & How-To about Sony Alpha DSLR-A580 Body Only Digital Camera
Mac Keynote Video Converter-Split and Join TM90 1080/60p AVCHD MTS to Keynote for Presentation
Convert/Join Panasonic HDC-TM90 HD Videos on Keynote for Presentation-AVCHD MTS to MOV
Embed/Store Converted/Joined H.264 mov Videos to Keynote '09-Mac TM90 MTS to Keynote Converter
I had recorded some .mts videos using Panasonic HDC-TM90 as part of research. I used Keynote to make presentation. I would like to insert the Panasonic TM90 HD Videos on Keynote for Presentation. However, the resulting HD videos are in AVCHD .mts files which could not be imported to Keynote. With the 1080/60p recording mode, the videos play great on the TM90 camcorder, however, Mac keynote is not compatible with this format, not even iMovie, Final Cut or others.
While looking for a solution to add recorded AVCHD videos to Keynote, Aunsoft Final Mate for Mac-Best Mac MTS to Keynote Converter is recommended as the partner to Panasonic TM90 MTS for Keynote presentation. It helps easily creating a vivid slideshow presentation with HD videos by converting AVCHD video to HD MOV.
Below is the quick guide to Embed Panasonic HDC-TM90 AVCHD MTS 1920*1080P videos to a presentation created with Keynote.
Step 1: Import/Capture Panasonic TM90 Camcorder AVCHD files to Aunsoft Final Mate for Mac.
Free Download Final Mate for Mac as a Mac Keynote Video Converter.When Aunsoft Final Mate for Mac is run, it can automatically detect and pop up a wizard for you to capture video from camcorder. The videos would be listed on the "Camcorder" tab.
Step 2: Create a Movie for converting TM90 1080/60p MTS files to MOV for Keynote.
Just select one or multiple mts video files you would like to convert, cut from the Camcorder tab and then drag and drop them to Movie tab. In this way, a Movie for conversion will be created.
Step 3: Splitting and Joining .mts Clips for Keynote on Timeline.
To cut/trim the video, just play it and click the Split button when it plays to the frame you want, and then click the" Delete" button next to the "Split" button to remove the unwanted .mts clips. As Final Mate for Mac is frame-accurate cutter, you can also pause the video, and click the Previous Frame or Next Frame for the exact frame you want to cut.
To "join" another clip to the end of the movie, just select the file, drag and drop to the movie ID. The files will be joined into one file as output.
Step 4: Export H.264 MOV video file for Keynote.
Click the Export button and choose HD MOV as output format. Follow HD Video > H.264 HD Video (*.mov) to choose export format for further sharing your presentations by keynote. In this way, all video clips will be merged as one single movie for keynote.
Tips: You are free to set/adjust output MOV files parameters (Bit rate - high quailty, Frame rate - 30, Resolution/Size - 1920 x 1080, channel - 5.1 channel) to make a good output quality.
After the conversion, I store the mov video on Keynote '09. Drag the Full HD MTS videos to Keynote on Mac,it is easy to display videos on business presentation.
Tips: If you want to import and edit Panasonic HDC-TM90 MTS on iMovie and Final Cut Express, Final Cut Pro , you can choose the Quicktime Movie Format > Apple Intermediate Codec (AIC) (*.mov) and Final Cut Pro > Apple ProRes 422 (*.mov) . AIC and ProrRes was advertised codecs to result in less compression and higher data rate/higher quality files for HD editing in iMovie/Final Cut Express and Final Cut Pro.
Sony Alpha DSLR-A580 Body Only Digital Camera Logo
Convert/Edit Panasonic HDC-SD9/HS700/TM700 to Mac, iMovie, FCP. FCE
Aunsoft Video Converter helps you convert between various formats. It is the must-have conversion tool for video lovers, and enables you to enjoy movies on computer, to further edit video for creation, to present video on HDTV, and to publish video online in web-friendly format. You can control your video and music on popular portable devices including iPad, Nexus One, HTC Hero, Zune, iPod, PSP, Apple TV, iPhone anytime anywhere.
With this powerful converter, you can also convert videos for video editing software like Adobe Premiere, Windows Movie Maker, Sony Vegas, and upload video to YouTube and MySpace to share videos.
Oct 19, 2010 | Computers & Internet
1,697 people viewed this tip
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
