Tip & How-To about Ovens
SEARS / KENMORE Range/Stove/Oven Manufacturers
SEARS/KENMORE
Sears is a department store. They do not build their own appliances. They contract with many different manufacturers to build all of their appliances. This chart will help you determine who actually built your appliance, then you can choose the manufacturer from the charts on this page.
The first 3 digits of the model number determine who built your Sears / Kenmore Unit. This can be helpful if looking for repair or replacement parts.
Your model is manufactured by the following if your units first digits starts with:
Amana 596
Caloric 174 / 960
D & M 587
Fedders 484
GE 362 / 363
Gibson 253
Jenn Air 829
Kelvinator 417 / 628 / 662
Litton 747
Maytag 925
Roper 103 / 155 / 647 / 835 / 911
Speed Queen 651
Tappan 79
Toshiba 562
WCI 790
Whirlpool 106 / 110 / 198 / 562 / 665
Ovens Logo
we cleaned my kenmore elite oven. now it won't work. when i try and turn it on i get an F23 error. do you know how to get the oven/stove working again?
Error code F 23 indicates the control detected a problem with the communication link or can be generated as a result of irregularities in the power supply or usage.
  • The error code F23 can often be resolved by removing power to the appliance for a minute and then restoring the power.
  • By unplugging the appliance it allows the control to receive a fresh supply of power. This in turn will clear the controls memory of any irregularities it may have received from the power supply. Once refreshed the error should no longer be displayed.
  1. Unplug the unit or turn the circuit breaker off for 60 seconds.
  2. Restore the power to the appliance by plugging it back in or turning the circuit breaker back on.
  3. Check to see if the error code is still displayed on the range.
  4. Run the appliance in the cycle that initially caused the error or attempt to turn on broiler.
If the error code is displayed, then service is needed. The unit should be inspected by a qualified appliance repair technician.
Should you choose to use Sears, the number to schedule a repair tech is: Sears Repair Department 1-800-469-4663.
Nov 23, 2010 | Kenmore Ovens
F-1 showing
It is a pretty common annoyance for many, some are able to disconnect the power and it seems to go away, but if it continues f-1 means EOC (Electronic Oven Control) Failure so if it persists it needs to be replaced. Maybe you had a powersurge recently or it could be just worn out
Sep 24, 2008 | Kenmore 41389 Electric Double Oven
1,338 people viewed this tip
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
