Tip & How-To about Televison & Video
Mitsubishi Convergence IC Part Number List
As there has been some serious errors made in identifying the IC's for Mitsubishi Convergence, I have posted the complete list for your use.
Mitsubishi Convergence IC Part # List (complete)
Ref # / Part # / Part Name & Description
CHASSIS: VZ7
MODELS: VS-45605 / VS-50605 / VS-50705 / VS-55705 / VS-60705 / VS-70705
IC8C01 267P141030 HIC- STK392-110
IC8C02 267P141030 HIC- STK392-110
CHASSIS: VZ8
MODELS: VS-45607 / VS-50607 / VS-60607 / VS-50707 / VS-55707 / VS-60707 VS-70707
IC8C01 267P141030 HIC - STK392-110
IC8C02 267P141030 HIC - STK392-110
CHASSIS: VZ9
MODELS: VS-45609 / VS-50609 / VS-55609 / VS-60609 / VS-60719 / VS-70709
IC8C00 267P155010 HIC - STK393-110
CHASSIS: VZ6-V15
MODELS: VS-70803 / VS-80803 / WS-65903 / WS-73903
IC8D01 267P120010 IC-H STK392-040
IC8D02 267P120010 IC-H STK392-040
MODELS: VS-50800 / VS-50803 / VS-60803
CHASSIS: V16
MODELS: VS-50805 / VS-60805 / WT-46805 / WS-55805 / WS-55905 / WS-65905 / WS-73905
IC8D01 267P120010 HIC - STK392-040
IC8D02 267P120010 HIC - STK392-040
CHASSIS: V17
MODELS: WT-46807 / WS-55807 / WS-55857 / WS-55907 /WS-65807 / WS-65857 / WS-65907 / WS-73907
IC8C01 267P150010 HIC - STK392-570
IC8C02 267P150010 HIC - STK392-570
MODELS: WS-55908 / WS-65908
CHASSIS: V18
MODELS: WT-46809 / WS-55809 / WS-55819 / WS-65809 / WS-65819
CHASSIS: V19
MODELS: WS?55859 / WS?55909 / WS?65869 / WS-65909 / WS-73909
IC8C01 267P155010 HIC - STK393-110
CHASSIS: V20B
MODELS: VS-A50 / WS-A48 / WS-A55 / WS-A65
CHASSIS: VK20
MODELS: WT-42311 / WT-A42
CHASSIS: V20
MODELS: VS-50111 / VS-60111 / WS-48311 / WS-55311 / WS-55411 / WS-65311 / WS-65411 / WS-73411
CHASSIS: V21
MODELS: WS-48511 / WS-55511 / WS-55711 / WS-65511 / WS-65611 / WS-65711 / WS-65712 / WS-73711 / WS-B55
CHASSIS: K20
MODEL: WT-42313 / WT-42315 / WT-42413
IC8C01 267P173010 HIC - STK394-250
IC8C02 267P173010 HIC - STK394-250
CHASSIS: V22
MODELS: WS-48313 / WS-48413 / WS-55313 / WS-55413 / WS-65313 / WS-65413
CHASSIS: V23
MODELS: WS-48513 / WS-48613 / WS-55513 / WS-55613 / WS-55813 / WS-65513 / WS-65613 / WS-65713 /
WS-65813 / WS-73513 / WS-73713
CHASSIS: V24
MODELS: WS-48315 / WS-55315 / WS-65315
CHASSIS: V25
MODELS: WS-48515 / WS-55515 / WS-55615 / WS-55815 / WS-65515 / WS-65615 /WS-65815 / WS-73615
Televison & Video Logo
how do u replace a IC convergence on a mitsubishi 65 tv
if you guys don't have experience or the right tools to fix board you will mess up your board.
so go to ebay and search for repair service listing #230735864835 and sen your board to this guy for convergence repair.
let a professional do the job for you and for cheap,why buying repair kits when you can buy the repair service?
Jun 18, 2012 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65809 The picture is blue and green because the light is out on the red can it be fixed? If yes how expensive?
Oct 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Red.yellow and green colors do not align. What is wrong? Isd it something I can fix?
If your picture has a 3D effect and you try to align with the cross hatches, then you have a convergence issue. I usually change both convergence IC's and any resistors that are open in the circuit. It requires unsoldering and soldering in the new convergence IC's. To locate the IC's, you can identify them as two side by side black chips about 3 inches by 2 inches with 18 pins each soldered to the board and on a metal heat sink. The numbers on them are identical and start as STK 392- 120 or 110. It is quite a job even for a skilled tv tech. After installing them and any resistor that is open, you will be able to align the cross hatches.
Jun 12, 2011 | Mitsubishi WS-55511 55" Rear Projection...
vs-45607 Vertical Hold Problem
Good Day; Just replace the caps first, 99.9% fix if not replace 9v regulator. Good Luck, big IRISH.
Nov 23, 2008 | Mitsubishi VS-45607 45" Rear Projection...
convergence board
It wouldn't be the entire convergence board, you more than likely have a bad convergence STK-IC. Replacing the IC will take a good bit of knowledge and training as far as electronic repair is concerned, plus a complete convergence set up. In other words, unless your certified, you need to contact a tech. The convergence set up alone has driven men to drink.....
Aug 28, 2006 | Mitsubishi VS-45609 TV
3,801 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
