Tip & How-To about Computers & Internet
How to configure router. How to access router configuration
When you buy a router they usually come with "setup" Cd's that set up your router, or guide you through the process. What most people do not know is you do not need this CD and in my experience these disc can cause frustration and confusion.
You can access your router and configure it simply by using your internet browser like Internet Explorer or FireFox.
On most routers(reference your user manual) you can access the router configuration page by going to the gateway address. The gateway address is the IP address assigned to your router. In a lot of the cases, this address is 192.168.1.1 but depends on your router.
There are a couple of ways to find out this IP address.
-Reference your router manual
or
-In Microsoft Windows, go to Start > Run and in the run box type "cmd" or "command". A black window should open(MS-DOS). In this window, type "ipconfig /all". Look near the top of the output that is shows and you should see a "gateway address" field. This number is the ip address of your router.
Once you know your gateway address, open up your internet browser as if you were going to go to a website. In the URL(address) bar, type the gateway address and hit enter(see image below). A log in box should now show. Again, reference your router manual if you do not know the administrative password. Enter in your password and username. The following website has a list of default username and passwords and you may be able to find your router in the list. Click here for the website.
Once you log in you now have access to the router settings and you can configure what you please. You can configure wireless settings, router log in credentials and other options. Have a look around and get familiar with it.
I would recommend that if your router has a default password for admin/configuration access, that you go ahead and create a new one. The default router passwords are usually very simple and this information can be easily found on the internet by anyone(as seen by the link I provided above!). People who set up home networks tend to leave this as is and it is a security risk.
TIPS
-If you can't connect to the router and you know the gateway address, try plugging the computer into the router directly using a Ethernet cable(LAN/patch cable). If you are still having trouble, you can perform a power cycle. Turn off your modem, router and computer. After 10 seconds turn on your modem, after 30 seconds turn on your router and after another 30 seconds turn on your computer. Try to access the router now. This also helps resolve other quirky router issues.
-Make sure all the network cables, phone lines(if using DSL) and coaxial cables(cable/Broadband) are plugged in and secured firmly.
-If you set up a password and username for your routers administrative access and can't remember it, you can reset the username and password back to factory default by performing a factory reset. On most routers this can be achieved by pressing and holding the small reset button on the back of the router for 15 seconds. Please reference router user manual for more information.
I hope this article was informative. Be sure to check out my other tips and tricks. You can view my profile by clicking here, and if you click Tips near the top left, you can view my tips!
Regards,
G33k
Keywords
How to configure router, how to access router, how to log in to router, how to configure router security, how to access router configuration, router configuration, set up router, how to set up router, setting up router, router settings
Computers & Internet Logo
Internet light/port lights flashing on WPN824 no connection
Try goto windows logo
in search box type cmd
when you get to black screen type ipconfig /release
when that finishes type ipconfig /renew
see if that resolve it.
Jan 12, 2012 | NetGear RangeMax WPN824 Wireless Router...
I need a simple set-up manual for model # WRT54GS router
Your Internet service provider is comcast cable company.
You need to open the setup page of the router and change the Internet connection settings manually.
Connect the computer to the router and modem to the router.
Open the setup page of the router using 192.168.1.1
Click on MAC address clone. Enable it and click save settings.
Power cycle the router and your main computer will be online.
Then you can change the wireless settings manually.
Click Linksys router setup steps
Jan 04, 2012 | Linksys Wireless-G Broadband Router
i have a linksys wireless g device,it was windows XP setup disk, now i upgrade to windows 7,but i failed to setup my wireless g? where can i have the windows 7 setup supports?
Linksys claims that all or their routers are compatible with Windows 7. You don't need the CD to setup the router. Open your browser and type in : 192.168.1.1
In the pop up box, leave the username blank and type in "admin" (without the quotes) for the password. Or use the username and password that you may have configured at an earlier time. Usually you can just select "setup" in the left sidebar and go from there.
You may have to do a hard reset on the router. Look for a very small button on the router, usually on the side or back. Press the reset button with an ink pin or similar object while the router is powered ON until the lights start flashing. The router is now returned to factory settings, like it just came new out of the box.
If you are having trouble go here: http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G
to download the user guide for your router. If you turn the router over you will see a sticker that has the model number and version. You'll need the version # to get the correct user manual.It will give you the info you need to setup the router.
Also, if you are still having problems, it may be that the wireless adapter is not compatible with Windows 7. You will need to go to the manufacturer's website and download the Windows 7 drivers (IF they are available.)
Please post back if you need further assistance.
Sep 04, 2011 | Linksys Wireless-G WRT54G Router
need to set up router
Provided you have a broadband internet connection (DSL or Cable), it is easy to install the router. There's a CD that came with the router and you can use that for initial setup. It will guide you through the process of installation.
Jan 11, 2009 | NetGear RangeMax WPN824 Wireless Router...
1,024 people viewed this tip
David Payne
David Payne
