Tip & How-To about Nokia Cell Phones
How to activate the Multimedia Messages (MMS Messages)
First ,you have to set the MMS messages by calling the Network Provider or Operator and ask for the MMS settings for your mobile.
Second, when you receive the settings (they will be sent as text message)Save and run if you been asked to run.
Third ,turn your mobile off for 2 or 3 minutes.
Fourth ,turn the mobile on .The MMS messages are now activated.
Cell Phones Logo
cannot recieve mms and cannot send mms
you have to ask the network provider/ operator for mms setting then you can save them as default and try to use them. call your sim operator/network provider service center now and as them for the mms setting for your mobile
Aug 08, 2011 | Motorola Mobility MOTOKRZR K1 Cellular...
how can i receive and send MMS to GT-S5233W? I don't know how to network mms on my phone.
The MMS service need to be set first.
The settings of MMS messages are provided by your SERVICE PROVIDER
Call your SERVICE PROVIDER,ask them send you the MMS settings of your mobile
After you receive them (they will be sent to your mobile as a text message) save them an run.
Then turn your mobile off for 3 minutes, then turn on.
Now the MMS service in your mobile is active.
May 28, 2011 | Samsung Star GT-S5233 Cell Phone
dcan anybody please tell how to make mms settings in samsung monte 5620 model
Hi, problems with mms message, mms settings are usually from your network provider
not your Cell Phone . In most cases, regarding the text messages,
the problem is from the Service Operator. Have you tried the Sim card on another phone? If not,
remove the Sim card, insert it on another phone and try sending a message from another mobile to you number,
If you can't receive or send mms messages even when it's inserted on another handset,
then you will need to call the customer care of your Network Operator and tell
them your problem, they will help you fix it immediately.
You can check the message center number, but I don't think
it's very much important in your case, well, if you wanna try,
just check the text message settings and verify that the message
center number (which is currently in use)or you can confirm by contacting your service provider service and they will assist you by sending you the settings for you mms message
and save the settings. Also disable the "Receive Via" or similar settings..
(I can't recollect the exact settings as i don't have the same model with
me, please excuse me for this.).
If the same Sim card doesn't receive text messages using another handset,
don't bother to change the settings or to make any changes with it,
first call the customer care and verify from them, you may make mistakes instead of fixing it.
Hope that helps.
Thanks for using fixya.......
Feb 08, 2011 | Cell Phones
I CANT SEND PICTURE MESSAGES WHY?
You need MMS and GPRS setting to send picture messages.
To make your
MMS and GPRS working you should first need the settings for it.You cannot set it.Your network provider should give the default gateway address for it.Then only you can use it.
If you already have set the
MMS and GPRS setting and now if it is not working because the network service provider would have changed the gateway Ip address.You have to again set the new one.
Please call your network service provider and ask him to send the
MMS and GPRS settings for your mobile.He/she will ask for the mobile model and send you the appropriate MMS and GPRS setting.You will get the settings as an SMS.go to iIbox and save the setting...
Now you can work with it.Your phone has no issues with
MMS and GPRS .Only network service provider has to give the correct settings.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Jan 02, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
Problem sending and receiving MMS
do you have your MMS settings in order? if not you need to speak to your telecom provider & ask for the settings.
Jan 08, 2009 | Samsung D900i Red Wine Quadband World GSM...
1,898 people viewed this tip
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
