Tip & How-To about Televison & Video
Sony TV Error Code - Seven Blinks
You try to turn on your Sony TV and nothing happens. Then you notice that the standby light is blinking. Counting determines that it is seven blinks about a second apart followed by about a three second pause.
Your problem is that the B+ (high voltage) is over the normal maximum value. You have a problem in the power supply regulation and horizontal circuit. It more than likely is a bad solder joint. Solder all the connections in the high voltage area. This is the area around the flyback transformer.
The flyback looks like a can and is at the rear of the TV in a Sony. It has large red rubber wires comming out of it. One of the wires is connected to the CRT near the top.
If this does not solve the problem I have a tip at http://www.fixya.com/support/r4916851-diagnosing_repair_tv_high_voltage which should be helpful to troubleshoot the problem.
If you cannot locate the problem or do not have the necessary troubleshooting skills a better plan may be to purchase a new circuit board.
Fortunately these days circuit boards are not that expensive. I would recommend replacing the defective board. The board with all the power supplies in a Sony is generally the "A" board and contains the High Voltage power supply.
Two of the best places to get the board are http://www.encompass.com or http://www.shopjimmy.com . Prices are similar but both sites are trustworthy and will allow you to return the boards if they are not the problem.
If you haven't replaced a circuit board I have a tip at http://www.fixya.com/support/r6981868-replace_circuit_board_in_modern_tvs which explains the process and should be helpful to complete the repair.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Televison & Video Logo
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
https://community.sony.com/t5/...blink...Red-light-flashing.../59141
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Nov 14, 2015 | Sony Televison & Video
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
4,096 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
