Tip & How-To about Cell Phones
I need pc suite software the LG cu920
You don't need software to transfer files. Here is what you need to do.
Go into your phone settings.
Click on Connection
Select USB Connection Mode
Select Mass Storage (You MUST have a 1g memory card or larger in the phone)
Connect the USB to your phone and your PC
Viola! your pc should recognize it as a mass storage device. Put files where you want them etc.
Cell Phones Logo
download from lg800g to computer
Is your Micro USB cable a "B" or "A"?Micro USB "B" is for data/charging.
Micro USB "A" is for charging only and will not work for any kind of data transfer (pins not connected).
The connector will be labeled at the micro usb end.
When you plug the cable into your phone a popup will ask you if you want to connect to mass storage. Once you answer yes, you can connect to the phone just like a usb drive.
Dec 13, 2011 | LG Cell Phones
How can I transfer photos and videos from my W595 sony ericsson mobile to my computer?
This can be in two ways namely
1. Via Bluetooth
Ensure your bluetooth connectivity is on and also enabled on your PC,Choose the picture or video u want to send,
Select More and then Send
Select Via Bluetooth and then choose your computer from the list.
OR
2. using the USB cable.
For pictures and videos, u use Files transfer.
File Transfer allows you to drag and drop files from your phone to folders on your computer. To do this,
a.Connect your W595 to your computer with the USB cable.
b.On your phone's Menu screen select Settings and then scroll across to the Connectivity tab.
c. Scroll down to USB and then select USB Connection
d.Select File Transfer.
Your phone will shut down.Wait until your phone memory or memory card appear as external disks on your computer in Windows Explorer.
then,You can now drag and drop music files (For Disk2Phone music software) or pictures, to folders on your computer.
Hope this helps you.
Sep 14, 2011 | Sony Ericsson Walkman W595 Cell Phone
i purchased some software to monitor calls on my daughters cellphone. the software was sent to me and i need to save it to my computer and then download it to my HTC thunderbolt phone. how do i do this?
The software installation file you have purchased is in "APK" format which is what Android will recognize as an application installer.
To install applications outside of the Market you must select/check "Unknown sources" which is located under "Applications" which is located under "Settings."
1. Connect the HTC Evo to your computer via it's USB cable.
2. Select mode of connection as "Disk Drive" (a menu with these options will pop up after connecting through USB).
After that is done, your computer will now recognize your HTC Evo as a Disk Drive.
3. Go to the location of the file you've download and want to transfer to you daughter's Evo- Select it, hold down "Ctrl" key while pressing the letter "c" (to copy the file).
4. Go to the location of the HTC Evo now known to your computer as a "Disk Drive" then hold down "Ctrl" key while pressing the letter "v" (to paste what you've copied).
Now that the file is on your daughter's Evo you simply need to:
1. Change the Evo's mode of connection from "Disk Drive" to "Charge Only" or just disconnect the USB cable.
2. Browse to the phone's app directory to start a file manager application (download one from the Market if you don't already have one- I recommend "ASTRO File Manager").
3. Navigate (using the file manager) to the file you've transferred to the phone and just launch it. The next prompt will ask if you want to install the application- select "Install."
Done.
Aug 13, 2011 | HTC EVO 4G Smartphone
i have albums in my pc and want to transfer the albums to my nokia 97?
Not sure if you meant photo album or music album??? Here is the steps for both, music first:
Transfer music from a
computer
You can use the following methods to transfer
music:
● To install Nokia Music to manage and organise
your music files, download the PC software from
www.music.nokia.com/download, and follow
the instructions.
● To view your device on a computer as a mass
memory device where you can transfer any data
files, make the connection with a compatible USB
data cable or Bluetooth connectivity. If you are
using a USB data cable, select Mass storage as
the connection mode.
● To synchronise music with Windows Media
Player, connect a compatible USB data cable, and
select Media transfer as the connection mode.
To change the default USB connection mode, select
Menu > Settings and Connectivity > USB > USB
connection mode.
This works for music, photos, or video:
Select Menu > Settings and Connectivity >
USB.
To have the device
ask the purpose of
the connection
each time a
compatible data
cable is connected,
select Ask on connection > Yes.
If the Ask on connection option is turned off or you
want to change the mode during an active
connection, select USB connection mode and from
the following:
● PC Suite — Use Nokia PC applications such as
Nokia Ovi Suite, and Nokia Software Updater.
● Mass storage — Transfer data between your
device and a compatible PC.
● Image transfer — Print images with a
compatible printer.
● Media transfer — Synchronise music with Nokia
Music or Windows Media Player.
Here is the link for your manual online:
http://nds1.nokia.com/phones/files/guides/Nokia_N97-1_UG_en.pdf
Oct 22, 2009 | Nokia N97 Cell Phone
258 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
