Tip & How-To about Cameras
How to Recover Pictures and Video from Kingston SDHC Card?
What's SDHC card?
SDHC (Secure Digital High Capacity) is an extension of the SD standard which increases card's storage capacity up to 32 GB. Its family includes SDHC, miniSDHC and microSDHC, and they have a capacity of 4GB to 32GB. It is FAT32 file system. SDHC cards share the same physical and electrical form factor as older cards, allowing SDHC devices to support both newer SDHC cards and older SD cards. For its huge storage ability, SDHC card was widely used to store music, video, photos as well as documents for all kinds of devices, such as digital cameras, camcorders, mobile phones, and portable computers. Kingston is one of the world's leading memory card manufacturers, its memory cards are known to have high data storage capacity, transfer speed and better quality. However, there are lees to every wine. Sometimes, we lost data due to bad luck.
Causes lead to pictures and video loss in Kingston SDHC card
Pictures and video loss can be caused by various reason, the following are some typical ones:
1. Accidental deleting: Delete files by right-clicking menu or just press "Delete" button in your digital camera.
2. Format SDHC card: Come across message reads "Media is not formatted, would you like to format now?" and press "format" or disk initialization when digital camera SDHC card is just connected.
3. Improper operation of Cameras or camcorders: you may forget to backup then factory set of device or turn off the storage media during the writing process. Using SDHC card between different cameras and pull out SDHC card while the camera is on will also lead to loss images and video.
4. Other reasons like unexpected devices power off or SDHC was attacked by virus when connected to PC will also loss data in it.
How to recover pictures and video from Kingston SDHC card
Every Kingston SDHC card contains a memory chip within the card. If the chip was intact, you are lucky, the data in your SDHC card should be still there and you can get them back. If not, there is no way to rescue. You can send the card to a reputable expert to help you get back pictures and video from SDHC card or just purchase Kingston SDHC card recoveryprogram like Card Data Recovery to retrieve data by yourself. Here are steps about how to use Card Data Recovery to help you recover pictures and video.
Step1. Insert Kingston SDHC card into a multi card reader if your PC does not support SDHC card in the SD card slot. Connect the card reader to your PC.
Step2. Download Card Data Recovery and install it in your PC, in "Disk Management", find SDHC card from the drive selection menu.
Step3. In the interface of Card Data Recovery, select "SDHC card" from the drive selection menu, choose "photo" or "video" in the right of interface and then click "scan" to begin scanning.
Step4. In the task list, chech photos and video, and click "recovery" to start recovery. Card Data Recovery allows you to preview photos and audio before recovery.
Cameras Logo
I just bought a Vivitar ViviCam T027 camera. The manual says it will accept sd cards up to 32 gb. My question is, will this camera accept the newer sdhc cards, or only the standard sd cards?
Hi there
Funny, I recently bought the exact same model. The answer to your question is simple (that's the good news!)
A long time ago, when these small SD Cards first appeared, they were limited in capacity from 128 Megabytes (MB) to a maximum capacity of 2 Gigabytes (GB).
To enable the same size card to store a greater capacity, a new specification had to be created. This new spec. was SDHC, and allowed the cards to store from 4 GB up to 32 GB.
The confusion arises because people still refer to all these cards as 'SD cards' when the higher capacity cards should really be called 'SDHC' cards.
Your camera will accept standard SDHC cards. Just make sure you don't order 'mini' cards which are much smaller in dimension.
Hope this clears up the confusion.
Phill R
Oct 04, 2010 | Vivitar ViviCam 3915 Digital Camera
sd card not recognizable
I read the following spec for your camera: Recording Media Internal Flash Memory 64MB Video/Image
SD/SDHC Up To 32GB Video/Image
So, I think that an 8 GB SD card should work.
Try another capacity and brand to make it work.
Jul 12, 2010 | Kingston 4GB Secure Digital High Capacity...
I just bought a new memory card-4 gb SD-K046. It says that the memory card is full but it is not. I have only used this memory card to scan pictures. I uploaded these pictures onto my camera and deleted them. For the first time I put it into my digital camera (kodak easyshare c330) and it will not work. Help?
The following information lists the type and maximum storage capacity of the memory card that each type of camera accepts.
EASYSHARE CX-, DX-, LS-Series Cameras accept:
DX3500, DX3600, DX3900: CF memory cards up to 1 GB
LS755: xD memory cards only
All other CX, DX, LS: SD memory cards up to 1 GB
EASYSHARE C-Series Cameras accept:
C300, C310, C315, C330, CD33, CW330, C530, CD40, CD50: SD memory cards up to 1 GB
C340, C360, C433, C503, C533, C603, C633, C643, C663, C703, C743, C875: SD memory cards up to 2 GB
CD43: xD memory cards only
All other C-Series Cameras: SDHC and SDHC UHS-1 memory cards up to 32 GB
EASYSHARE M-Series Cameras accept:
M590, M583, M577 TOUCH, M5370 TOUCH: MicroSD and MicroSDHC memory cards up to 32 GB
All other M-Series Cameras: SD, SDHC, SDHC UHS-1 memory cards up to 32 GB
EASYSHARE P-Series Cameras accept:
P850, P880: SD memory cards up to 2 GB
P712: SD or SDHC memory cards up to 4 GB
EASYSHARE SLICE Digital Camera accepts:
MicroSD and MicroSDHC memory cards up to 32 GB.
EASYSHARE V-Series Cameras accept:
V1233, V1253, V1073, V1273: SDHC, SDHC UHS-1 memory cards up to 32 GB
All other V-Series Cameras: SD memory cards up to 2 GB
EASYSHARE Z-Series Cameras accept:
Z610, Z650, Z700, Z710, Z730, Z740, Z760, Z7590: SD memory cards up to 2 GB
All other Z-Series Cameras, including MAX: SDHC and SDHC UHS-1 memory cards up to 32 GB
FUNSAVER FD-Series Cameras accept:
SD and SDHC memory cards up to 32 GB
EASYSHARE ONE Camera accepts:
SD and SDHC memory cards up to 1 GB
Notes:
Most KODAK Digital Cameras are compatible with SD, SD/MMC, and/or SDHC memory cards.
Most current KODAK Digital Cameras are compatible with SDHC UHS-1 memory cards.
All KODAK Digital Cameras that are compatible with SDHC and SDHC UHS-1 memory cards use cards with Speed Class up to Class 10.
MicroSD and MicroSDHC cards with SD adapters can also be used in cameras that use SD or SDHC cards if the storage capacity criteria above is followed.
KODAK Digital Cameras are not compatible with SDXC memory cards.
reference: http://www.kodak.com/global/mul/service/index.html?reqURL=http://support.en.kodak.com/app/home/src/gosupport
http://support.en.kodak.com/app/answers/list/p/2/selected/true
Phone Number for Kodak is:
800-235-6325
or try get human below for more info on support:
http://gethuman.com/phone-number/Kodak/
Jun 11, 2010 | Computers & Internet
what is the maximum SD size that will work with the DSC-4500Z camera?
The manufacturer of your camera specifies SD card compatibility without providing a specific number. This is not uncommon however, as the maximum size for SD cards is 2 GB. Cards that have a larger capacity than 2 GB in the "SD" format are "SDHC". Read the label of these cards (that have a larger capacity than 2 GB) that *look* identical to SD cards, and you'll see that they are in fact SDHC types. The SDHC card can have a capacity of up to 32 GB. A device that is compatible with the SDHC specification should be able to read any SDHC card *and* any SD card as well; because the standard requires "backward compatibility" to the older SD standard. A device that accepts SD cards should be able to read any SD card, *but* if an SDHC card be introduced to it, it may provide unreliable results (from being able to access only 2 GB of the capacity or not recognizing the card at all). Make sure your pictures are safe and don't get lost; use only SD cards in this camera.
I hope this helps!
Jun 08, 2010 | Apex Digital Digitrex DSC-4500Z Digital...
Please can you tell me if an SD card called SD Ultra 11 66X 2GB will be read by a standard SD card reader
Yes, i t should be unless it is a SDHC Card which it should not be as SDHC cards have minimum 4 GB capacity. For more info:
The older SD (secure digital) cards had a maximum capacity of 2GB. The SDHC (secure digital high capacity) cards can go to 32GB. Devices that support SDHC will say so in their specs and they will also read older SD card. Older devices that use SD cards will NOT use SDHC.
"SDHC (Secure Digital High-Capacity) cards are flash memory cards with a minimum capacity of 4GB (gigabytes). SDHC cards provide removable memory for compatible digital devices including cameras, camcorders, PDAs, MP3 players and more.
Dec 14, 2009 | Audio Players & Recorders
252 people viewed this tip
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
