Tip & How-To about Computers & Internet
How to Recover Files and Photos from SanDisk USB Drive?
SanDisk USB flash drive is widely used for its excellent quality. It gives customers all the power and performance you need to transfer, store and share pictures, tunes and data with easy. Some uses of SanDisk USB flash drive can be concluded in the following aspects: personal data transport, secure storage of data, application and software files, application carriers, computer forensics and law enforcement, backup, etc. Compared with other storage devices like floppy disk, USB carries various advantages for Small size, lightweight, rewriteable and removable. Therefore, it becomes a necessary among business man and students.
However, Data loss often happens on USB flash drive as well. Some of them are caused by the products of USB, others due to the false operation of it. Here are some typical reasons that cause data loss:
1. Windows system asks you to format USB drive and you accidently press "Format";
2. Mistakenly or carelessly delete files from USB flash drive and cannot find them in the recycle bin or trash bin;
3. The drive was attacked by virus and files get hidden or deleted;
4. Not properly remove the USB drive from computer when the data was still transferring;
5. The file system of USB drive was displayed as raw;
7. Hardware malfunction
It is really frustrated if you find crucial documents, previous pictures or applications lost. Are there any methods to get them back?
Data loss caused by hardware malfunction will be very hard to restore. You have to ask the help of professional technician. For other cases, you can rely on some USB flash drive data recovery program to help you. Once loss data, you should stop using USB any more in case the data was overwritten. There we recommend you Card Data Recovery to help you rescue USB flash drive data.
Step1. Download Card Data Recovery, save it to your computer's desktop and double click on it to open the program;
Step2. Insert SanDisk USB flash drive into USB port of your PC;
Step3. Run Card Data Recovery and select SanDisk device from the drive selection drop-down menu. Click "scan" to scan the USB drive and you can find deleted or lost items will be displayed in the task list;
Step4. Select the files you wish to recover from USB drive and click "Recovery" button. Card Data Recovery allows you to preview files before recovery.
Card Data Recovery also supports recovering data from SanDisk memory card, SD card, mobile SDHC card, etc.
Computers & Internet Logo
lost files in USB memory flash
Asoftech data recovery program can recover data from formatted, lost or damaged hard drive or partition, Ghost hard drive .
# Recover lost, formatted or deleted ( word ,excel ,ppt, office document, video zip, photo files etc ) from hard drive, Support USB recovery and other disk recovery .
http://www.asoftech.com/adr/
Jun 11, 2012 | SanDisk 16Gb USB Flash Drive
bought 4gb sandisk cruzer flash drive stored music from computer but it won't play the music on the car fm transmitter
a flash drive is used mainly for storing of files, you need a device that will play the files you want, in this case a device that plays mp3s and either transfer your music to/through it.
Unless your transmitter states that it plays different media formats that is but i have never heard of that before.
hope this helps.
Dec 08, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
i am having one 4gb pendrive its not opening. now im inserting my pc please recover it.
Don't be panic. you can try some data recovery software. You can see
http://www.asoftech.com/adr/index.html
It tells the steps how to perform data recovery.
If above does not work, you may have to format the pen drive (use quick format), and then use above mentioned software to scan again the pen drive and recover your files.
Apr 05, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
am trying to transfer DVD disc to Sandisk flash drive. What's the process? Thanks V
it sounds like you need to creat an .iso file from the dvd then drac and drop. is you flash drive 4 Gb
Jun 24, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
how to use flash drive
Cruzer Micro is an USB external memory where you can store files.
It is automatically detected and installed on all Windows OS from Windows 2000 onward, same on Mac OS and recent Linux versions.
All you have to do is plugging the device into USB.
After the flash drive had been automatically installed , it will be displayed under Computer as an external disk.
You can copy and transfer files using Cut, Copy and Paste functions, or Send to function in windows, or the file manager, depending on the OS used.
In Windows, before unplugging the memory from USB , it is better to turn off the computer or use the 'safely remove USB' function located near to the clock, on the lower right hand corner.
Read also the documents below:
Introducing the Cruzer Micro
Find Answers || BeCompliant Corporation
How to Use Sandisk Cruzer Flash Drive
May 15, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
250 people viewed this tip
David Payne
David Payne
