Tip & How-To about Office Equipment & Supplies
Printer stops printing before toner cartridge is empty.
You have to keep replacing your toner cartridge before it is empty. It could be anywhere from 1/4 to 3/4 full and the printer says that it is empty and needs to be replaced.
This happens because of the sensing mechanism used in toner level sensing system. For the printer to know when the cartridge needs to be replaced manufacturers generally use a simple, and generally reliable system of infared emitters and sensors. An infared beam is shined through the toner cartridge from one side and a receptor senses the beam on the opposite side. As long as the beam can't shine through the cartridge all is fine and the printer thinks that the cartridge has toner. When the beam is detected by the sensor the printer thinks the cartridge is getting empty. All you need to do for a sensitive sensor is to block the path. The only thing you will lose is the ability to be warned when the toner is getting near empty. As long as you have a new toner cartridge on hand this should be of no consequence.
To defeat the sensor remove the toner cartridge and look at both ends. There should be a clear window on each end for an infared beam to shine through. When full of toner the beam is blocked. If you have a sensitive sensor which can detect the beam before the toner is gone you will get a warning before the toner is completely gone.
Carefully place a small piece of opaque tape, (masking or electrical tape) across the window to block the beam. Make sure that the tape is secure and will not fall off inside the printer. This should solve your problem and allow your printer to print until the toner is completely empty.
Thanks for using FixYa and for the great rating.
hardrocko
why does richo aficio 2016 copier keep asking for toner hen toner is full
As long as the toner sensor senses it is empty, it will keep telling this. Or the sensor is defect, or a cable came lose, or perhaps you only have to shake the toner cartridge a few times. Be aware it is open now.
Jul 16, 2014 | Ricoh Aficio 2016 All-In-One Laser Printer
toner empty error
In order for your printer to read the cartridge as full the chip on the toner will need to be replaced/reset. Sadly these cartridges are unable to physically check toner levels and rely upon counting pages/page coverage to estimate.
Dec 06, 2012 | Ricoh Aficio Sp 1000sf All-In-One Laser...
Streaking on left side of page
there are some possibilities for this problem. i will explain it. 1) First of all check out if the toner is full ,half or near to empty. There is no exact procedure to check the powder left in the toner without opening the toner.but in one toner there comes about near to 1500 copies.if you have got about 1200 to 1300 copies.then its quite possible that the power left is near to empty so the streaks comes on the paper due to less powder left.many times in this case removing and shaking the toner then reinserting the toner again and checking the printout helps. 2) But if you are sure that toner is not empty then other possibility is.in the toner cartridge there is a aluminium drum.its easily seen in the cartridge.once you remove the cartridge. if that drum is got very much used then due to that drum the streaks appear.fox example.if the drum is new the print is very dark.if the drum gets old the print gets very light or with streaks or faded print. 3) Now if drum and toner powder both are proper and still the problem then its the fault in the printer.in your printer there is some toner powder got spilled out on the inner parts from where the printing paper passes.so when the paper passes from the part where the powder is fallen or got collected then the streaks comes.in this case the printer needs internal cleaning and servicing. 4) but in some cases it has been noticed that internal powder of the toner becomes moist and very hard to come out from the toner for printing.in this case either toner needs to be refilled or toner needs to be replaced.you can get the toner refilled from local cartridge refilling store or local stationery shops dealing in cartridge refillings.The cartridge refilling shops also have the same printer for checking the cartridge.so at the refilling shop it will be confirmed whether the fault is in cartridge or printer.
This will help. Thanks please keep updated. please please do rate the solution positively .thank you for using fixya
Mar 18, 2010 | HP LaserJet 1200 Printer
Toner level
To check the toner level, there is a little clear window on each cartridge you can use for this purpose. Hold the cartridge vertically. If you see toner in the window, it is more than half full (or less than half empty, ha!). If not, slowly tilt the cartridge toward the side with the window. Essentially, how far you tilt it before you see toner determines how far below half full it is. If you pass a 45 degree angle before the toner appears in the window, it is nearing empty and must be replaced or refilled (yes, refilling is an option).
If you do have to replace or refill, don't forget to empty the waste toner bottle (responsibly, of course). By the time you run low on toner in one of your cartridges, the waste toner bottle will likely be nearing capacity.
Jun 19, 2009 | Konica Minolta Magicolor 2530 DL Laser...
563 people viewed this tip
k24674
jasbo
jasbo
