Tip & How-To about Grilling
Cleaning Rust From Barbeques
You can buy proprietary rust removers at your local hardware store but try this first. Remove as much rust as you can with a scrubbing pad or wire wool. Pour vinegar on the plates and rub it into the rust. Try not to let it run over the edges of the plate. Allow it to soak for 15 minutes to dissolve the rust and then rub away the residue. If this doesn't remove all the rust you can try scrubbing with a paste of bread soda. You can also try scrubbing with a paste made from salt but the disadvantage with salt is that it can cause corrosion if you don't clean it all off afterwards.
Grilling Logo
how do I remove rust from a plastic container
You can try soaking it in chlorine bleach, but be sure that you clear the container of any residual bleach before using it again. Chlorine bleach can react adversely with many other chemicals and/or organic substances and can be poisonous to pets and humans.
Nov 02, 2014 | Cars & Trucks
How can I help clean the rust from the bottom of my ford windstar 2003?
Scrape off the rust, using a wire brush or scrubbing pad. This technique removes small rust. GM MDI
Apply a rust remover, using a steel wool pad or paper towel. Rub the rust remover into the rust.
Wait 10 minutes for the rust remover to work. Most rust removers contain hydrochloric acid, oxalic acid or other strong acids that dissolve rust.
Clean away the rust remover and the rust with paper towels. Dampen a paper towel, and wipe the areas, again.
Paint on a primer with a paint brush. Let the primer dry. The automotive primers offer protection against rust.
Use touch-up paint that is the same color as the Ford Galaxie. Apply it to all areas that are missing paint. Let the paint dry, before driving the car.
Sep 15, 2014 | Cars & Trucks
My barbeque has been stood under a cover for a year & the two plates which you cook on have gone rusty. Is it possible to buy replacements or how do you suggest cleaning them?
You can buy proprietary rust removers at your local hardware store but try this first. Remove as much rust as you can with a scrubbing pad or wire wool. Pour vinegar on the plates and rub it into the rust. Try not to let it run over the edges of the plateAllow it to soak for 15 minutes to dissolve the rust and then rub away the residue. If this doesn't remove all the rust you can try scrubbing with a paste of bread soda. You can also try scrubbing with a paste made from salt but the disadvantage with salt is that it can cause corrosion if you don't clean it all off afterwards.
Jun 06, 2011 | Garden
looking for touch up paint or solution for rust around wheel well
You need to remove all of the rust with a grinder then a wire wheel. Treat the rust with rust with a rust coating this will turn it black. Visit your local FinishMaster store and get the right code of paint, these guys are great and will steer u in the right direction
Mar 04, 2010 | 1999 Ford Expedition
1,624 people viewed this tip
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
