Tip & How-To about Dryers
Clean Your Dryer Vent to Prevent Fires
Most people have no idea how much lint gets past your dryer's lint trap. The amount is substantial. Over Time your dryer vent pipe becomes coated with dryer lint. If your dryer vent hasn't been cleaned in over a year, you may have a potential fire hazard on your hands. Once the vent becomes restricted your dryer will take longer to dry a load. Lack of airflow will cause your dryer to over heat. If your dryer vent is over eight feet long, your dryer vent should be cleaned annually. Some of the early warning signs of lint blockage include:
  • Is the top of your dryer hot to the touch?
  • Does your dryer take over 50 minutes to dry a load?
  • Do you ever experience a moldy smell on your clothing?
  • Is dryer lint gathering on the inside of the dryer door?
  • Does it seem like your clothes have extra lint on them?
  • Is your house dusty? Dryer lint is almost microscopic and goes everywhere.
Most dryer vents have a flap or a screen located at the exit. This must be cleaned on aregular basis. Where your dryer vent exit's the building is usually the first place dryer lint will gather. It is very important when you have your vent cleaned they address the exit.
Dryer vents come in all different shapes and sizes. The dryer vent itself refers to the exhaust pipe inside the wall. This pipe should be a 4" steel pipe that exits right outside or some times up through the rooftop. Some builder's occasionally use the more rectangular gutter piping, or the flexible metal piping. Both of these can be inefficient. If your home has a foil accordion type material inside your wall, this needs to be replaced immediately. This material is actually flammable, if you ever had a dryer fire it would have no chance of staying contained.
A dryer vent that exits on to a tile roof can pose another potential airflow restriction. Much of the time builders use the same gooseneck type exit as on a standard shingle roof. Unfortunately these vents aren't long enough, and tend to vent right on the tile with very little space. The fix for this problem is to fabricate an extension that raises the vent at least four inches above the tile.
Another common problem is a crushed transition tube. The transition tube is the pipe that connects the dryer to the wall vent. Most of the time delivery people use the foil type transitions because of ease of installation. Unfortunately this material can easily become crushed or restricted. This type of material is actually paper and can ignite. Unlike the all metal venting material that the dryer manufacturers recommend this material is a real fire hazard. (see your owner's manual or the labels on back of the dryer.)
Unfortunately a blocked dryer vent can break your dryer. The two main parts that break, are the element and the thermostat. The excessive heat produced by a blocked vent is a repair waiting to happen. Many of the new high efficiency dryers have warning lights that tell you when your vent needs cleaning. Some of these dryers even lower the temp on their own to keep from overheating.
The best way to test your dryer vent's efficiency is to disconnect the tube from the wall and dry a load of clothes. If your clothes get dry in a reasonable time it's your dryer vent. Over 15,000 dryer related fires occur every year. Most of these fires could have been prevented, with an annual vent cleaning. Don't become a statistic get your dryer vent professionally cleaned today.
Dryers Logo
it is not drying very well even on the very dry setting, why?
This may sound silly, but have you cleaned the dryer vent pipe from the dryer to the outside of your house? If that vent pipe is plugged, or partially plugged, your dryer will not dry properly. When I have had this problem in the past, the first thing I do is take the dryer out of the house and blow it out with a leaf blower. I put the leaf blower nozzle in the vent trap area, pack a towel around the blower nozzle, turn it on high and watch the lint fly. This ensure the dryer is cleaned out of any excess lint. Next, I take my leaf blower into the house, put the nozzle in the vent pipe (packing a towel around it also) and turn it on high and blow all the lint out of vent. I would caution you to check your piping the make sure all the vent pipe sections are secure. (The first time I blew out my vent pipe I had lint all over my basement due to poor connections in the tin piping. I promptly took aluminized duct tape and covered all of the seams.) My dryer always drys so much better after doing this simple procedure.
Feb 19, 2010 | Bosch Dryers
odor around the lint trap, cleaned but persists
The lint trap is an opening into the dryer vent and vent pipe. The dryer needs to be pulled out from the wall, the vent pipe disconnected and then the back of the dryer and the entire pipe cleaned of lint and other debris. this is the only way to get rid of the odor.
May 20, 2009 | Dryers
My lint trap has very little lint.
Older clothes do not produce as much lint as new ones. Also, if your dryer isn't getting as hot as it used to, then you won't get as much lint either. Does it seem to take a bit longer to dry your clothes? Also, check your dryer vent, if the airflow is reduced, the amount of lint that is expelled through the filter will deminish as well. You may have a build up of lint in the vent ducting to the outside that is restricting airflow.
Apr 08, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Kenmore Elite Heavy Duty Dryer 11063012101 Takes Forever to Dry
I think your vent has lint in the line between the wall and the outside of your house not allowing the moisture to get out
FIX
1 when the dryer is running go outside and observe the vent to see if hot air is coming out
2 Turn dryer off, disconnect electric from wall
3 pull dryer out from wall
4 take a nut driver or screw and remove the clamp that attaches the flex vent pipe to the wall
4 Also remove the flex pipe from the dryer
5 Inspect inside vent connection inside dryer for any trapped lint
6 inspect inside flex line for any lint
7 Look inside wall vent for lint you can also reach in with your hand to feel for lint
8 If you have a leaf blower or can borrow one(electric is best) from your neighbor put the snout of the blower into the vent going into the wall seal the area between the snout and the vent pipe at the wall ( i use duct tape you can use wash clothes rags etc
9 start blower and blow any lint in the line out through outside THIS WILL CLEAR THE LINT
10 Reattach the flex to the wall vent and dryer , plug in. run a load and you should be back in business
Good Luck
Jan 04, 2009 | Kenmore 63012 Electric Dryer
I want to know how to remove the lint trap (not just the screen but the entire assembly) from a Maytag Performa PYET344AZW front loading electric dryer. The lint screen will not even properly slide back into place because there is so much lint within the plastic frame (and probably in the ducts and everywhere else too!).
Besides drying clothes, dryers also remove lint. This fine, fuzzy material can cause trouble because it blocks dryer lint traps, clogs vents, and fills blowers. Lint can also gather around and in the tracks of the drum rollers, or in and under the pulleys and the drive belt. The result is poor clothes drying or -- sometimes -- no drying. To avoid lint problems, clean out the dryer's lint trap system every time you use the dryer.
To clean the lint screen, remove it from the unit. The screen may be located near or under the door sill, or in the top of the dryer near the control panel. It can usually be removed by pulling it up and out of its housing. Remove the accumulated lint to clear the screen; then replace the screen.
The exhaust vent also collects lint. Vent maintenance involves cleaning the lint from a screen in the dryer's vent exhaust collar and/or at the end of the exhaust vent where it sticks out through a basement window or through an exterior wall. To clean the screen, remove the clamp that holds the vent to the collar, or back out the screws that hold the vent to the collar, or pull the vent straight off an extended collar. Clean the screen thoroughly and replace it in the vent assembly.
To clean the vent itself, use a vent-cleaning brush (available at hardware stores) to pull out any lint deposits. Also check the vent run to make sure that the vent piping or tubing isn't loose at the joints, or -- in the case of flexible plastic venting -- isn't sagging between hanging brackets. Breaks or sags cause undue strain on the dryer's blower system, and can cause drying problems. If the vent pipe or tubing has become clogged with lint, remove the lint by pushing a garden hose or a drain-and-trap auger through the vent to a convenient joint. Disassemble the joint to remove the debris. With this procedure, it isn't necessary to disassemble the entire vent to find the blockage.You can head off problems before they become too serious by providing routine maintenance for your dryer's door gasket, thermostat, timer, and other frequently used parts. Let's discuss how to service these important components in the next section.
how-to-repair-a-dryer-1.jpgTHANK U.. RATE IT...
Sep 11, 2008 | Dryers
389 people viewed this tip
Top Dryers Experts
Dan Webster
Dan Webster
