Tip & How-To about Hotpoint First Edition FEW12 Front Load Washer
Save on running costs.
Our clothes rarely get dirty, just need freshening really, and I got sick and tired of waiting almost 2 hours for the programme to stop.
I checked the times of different settings and found that programme J... silks.... only takes around 1 hour, washes at a higher water level and is around 40 degrees.
Now I never use any other programme. Dont over load your machine, dont put too many towels in as this programme is designed for 3kg, so check the weights till you are used to how your drum looks with different types of clothes etc.
We rarely need a heavy wash, and if I do I feel its better to do 2 light washes than do 1 protracted wash in the same water.
Im saving fuel and getting my washing done in half the time too.
sue
Hotpoint First Edition FEW12 Front Load Washer Logo
Explain the freshen up programme
Best use a cleaning product like Dr Beckmann's
Nov 02, 2014 | Washing Machines
When excelerate to 70 mph my steering wheel vibrates. What should I do?
This is very common. It can either be your tires need to be balanced. Or your car needs to be aligned at an alignment center. One or the other should stop the vibration.
Aug 05, 2009 | 2005 Lincoln LS
my ac stopped putting out cool air on a hot day. I turned off the ac and replaced 2 dirty filters and waited 4 hours to turn back on but the air does not seem cool. Did I not wait long enough time for it to defrost???
check to see if the fan is working at the condensing unit. if it is, check that the fan is pulling heat off the unit as it should. make sure the cage is clean. no restrictions as far as air flow. clean . check duct work for leaks. inside, if you replaced the filter/s. the evaporator is dirty. call a prof,
Apr 25, 2009 | Ruud UBHC Air Conditioner
2,400 people viewed this tip
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
