Tip & How-To about Heating & Cooling
Accurate Charging Methods of Central Air Conditioners
The charging (of an air conditioning system) alone can have a substantial impact on system operation costs. A few percentage points of over-or undercharge can raise electricity consumption significantly and shorten the life of the compressor." You must invest in the proper tools, training and methodology to accurately charge an Air Conditioning system so that it works at maximum efficiency. Using the Thermocharge method to charge your air conditioning systems to the exact charge needed will save hundreds to thousands of dollars in electricity and maintenance costs over the years!
Thermocharging method
Skilled technicians will "Thermocharge" your air conditioning system with an exact refrigerant charge. This procedure produces an exact charge . . .not approximate, but exact. The Thermocharge method requires special equipment and training to use. Your installer uses the following instruments:
  • 1. An electronic thermometer
  • 2. Sling psychrometer or electronic humidity measuring device
  • 3. Refrigerant pressure gauges
  • 4. Accucharge slide rule calculator
Here the tech is using the sling psychrometer to obtain the indoor humidity and indoor air temperature. He will double-check his figures with the electronic thermometer laying on the table. He will also verify the readings with an electronic psychrometer.
After recording the indoor humidity and temperature the tech will go to the outside condensing unit to take additional readings. These are the following:
  • 1. Outdoor temperature
  • 2. Indoor humidity
  • 3. Temperature difference, between air entering the evaporator coil, and the air leaving the evaporator coil
  • 4. Suction line temperature
  • 5. Suction line pressure
  • 6. Liquid line pressure (smaller copper line)
Enter this information into his special slide rule calculator to determine the exact amount of refrigerant to put into your air conditioner.
Let it run for about ten minutes to verify his figures. If there are any discrepancies, start the procedure all over again from the beginning.
This Thermocharging method of charging an air conditioning system takes time and patience, but it guarantees that theair conditioning system will operate at peak efficiency all season long.
How does accurate refrigerant charging help?
  • Improved comfort - A improperly charged air conditioner will not dehumidify properly.
  • Lower maintenance costs - A poorly charged system will not properly cool or lubricate the compressor . . .significantly shortening its life.
  • Better cooling and efficiency - Improper charging means that the air conditioner will not provide enough cooling on hot days, causing the system to run longer.
  • Improved efficiency and lower electric bills - Poor heat transfer from improper charging results in increased power consumption. A 15% undercharge or overcharge can result in a 25% decrease in efficiency. This means that the homeowner's electric bill will be 25% higher than necessary. As the charge drops farther, efficiency decreases faster to 50% or more.
  • Increased reliability - A poorly charged system will not properly cool or lubricate the compressor . . . significantly shortening its life. Even if you have extended warranty by a heating company, you will either be greatly inconvenienced or even end up paying for the repair if the company stalls and you end up paying another company for the work . . .a $300-$700 repair that will void the warranty.
Heating & Cooling Logo
What is Powershield³ UPS Monitoring Software??
PowerShield³ offers you very user-friendly UPS software which shows real time information in the form of bar charts and values for data like UPS load, mains voltage and battery charge percentage. This software allows operating parameters to help diagnose fault conditions and alarms
Aug 12, 2010 | Belkin Computers & Internet
air condition blows hot air but it has freon
You may have created an over charged condition and at this point the a/c compressor will cut off on high head pressures. This can be verified by installing gauges to the systems high and low side service taps and reading the pressures.An overcharged system will start the compressor briefly but soon cuts off once pressure goes to 350 - 400 lbs on the high side. Acceptable pressures for this system should be no greater than 250 high and low suction should drop to 40-50 psi.You might recover the charge and evacuate the system,then try bringing the charge back to proper level.A sight glass in the reciever drier really helps determining proper fill.Once all bubbles have dissipated from the sight glass during charging ,one should stop at that point to avoid overfilling.Too much freon is worse than a low charge especially in hot ambient conditions....
Aug 26, 2009 | 2003 Saturn ION
How much are they worth?
1984 Suzuki GS550ES Value July 4, 2009
  • 4-Cylinders
  • 4-Stroke
  • 575cc
Suggested Retail Value $1080 The Kelley Blue Book Suggested Retail Value is representative of dealers' asking prices and is the starting point for negotiation between a consumer and a dealer. This Suggested Retail Value assumes that the unit has been fully reconditioned and is in excellent condition. Mileage/condition and additional equipment may have a substantial impact on the value shown above. This value also takes into account the dealers' profit, costs for advertising, sales commissions and other costs of doing business. The final sale price will likely be less depending on the unit's actual condition, popularity, type of warranty offered and local market conditions.
http://www.kbb.com/motorcycle/retail/1984/suzuki/gs550es/78681
Jul 05, 2009 | 1984 Suzuki Gs 550 L
502 people viewed this tip
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
