Tip & How-To about Plumbing
Plumbing Repair// a water pipe with water in pipe
Broken,split,frozen pipes that need solidering and you can't do it becasuse of water leaking into repair area?
A simple way to keep water out of repair area is to stuff white bread into the pipe that has the water leaking into it. It will absorb the water while you make repair, depending on the flow of the leak ,will determine on how much time you have to complete the repair. This happens quite often when the water valve is not closing all the way.
After the repair simply turn on the water and flush out the bread.
2 inportant steps to remember; 1 remove the crust from the bread, 2 remove areator from facuet before flushing out the bread .
Plumbing Logo
I got a 2005 homestead rv and the water pipe broke or froze up how can I check and fix it
Water pipes in RV are Pex, which is not the same as PVC. Pex will freeze, but is designed to not burst when frozen. If you have located the broken pipe, it is simple to replace. Using a PVC cutter (looks like cheap shears) cut out the broken piece. Most likely the pipe size will be 1/2 inch. Pex comes in three different colors: white, red, and blue. Most likely the RV pipe will be white, but the color does not matter as the pipe is of the same material. Pex can be bought at stores like Home Depot, Lowes, or other hardware stores. The connector fittings can be bought at the same stores. The simplest to use fittings are the push-on self sealing fittings. There are cheaper fittings, but they take special tools to install them. The estimated cost of a 2 foot distance pipe repair is about $10 to $15. The time required depends on how difficult it is to "get to" the broken pipe.
May 28, 2015 | Water Water Heaters
water leak
The most common reasons for water leaking from the unit are:
1- Condensate drain line clogged, needs cleared.
2- System is freezing up, causing excessive water to overflow, check filter, fan motor, thermostat, and batteries.
If there is ice on the lines on the indoor or outdoor unit, the system is frozen. If it's a charging issue, make sure system is thawed completely before calling anyone. They will not be able to do anything until system is thawed out and will cause you to wait longer.
Sep 01, 2014 | Goodman CLQ36AR49 Air Conditioner
my water pipes are frozen. there is no running water in doors. how do i thaw this safely?
Is this an air conditioner problem?
If not, open all faucets, all cabinet doors under the sinks, and allow the pipes to thaw slowly. Find your water source shut off valve.
See if you can find where the pipe is frozen. Do not use a propane torch. Use a hair dryer if you are not in standing water to heat the area of the pipe that is frozen. Once the water starts flowing at the faucets, allow it to run for a few minutes. The relatively warm water will melt any ice that may be forming in your pipes. Once you shut off the faucets, verify that you don't have water running anywhere - you are looking for broken pipes.
If you have found the area(s) where the pipe has frozen, insulate that area before there's a next time. If need be, add some self regulating heat tape before insulating the pipe. Good Luck
Jan 09, 2014 | Heating & Cooling
LG Fridge-Tube where water dispenses in ice tray is frozen solid
I think that the solenoid valve that supplies water to the ice maker is leaking ,it is located in the back of the refrigerator where you see a copper pipe or plasticpipe thatfeeds water to the refrigerator. Shut the water off and the power and take it out and replace it .
Apr 10, 2009 | LG Refrigerators
pipes
Well if it is going to be freezing for some time you could rent a kerosene force heater and keep the underside of the trailer warm to prevent this from happening again until the weathe allows you to insulate the piping. As for the current leak shut off the water to the trailer and buy a couple of Quest Tees and couplings in the 1/2 and 3/4 inch sizes. You will also need a hacksaw to cut the piping. Be prepared to sit the insulation under the trailer and discover that the leak is not in that area. If you can't visually find the affected pipe have someone gradualy turn the water on until it is identified. Once it is you can cut the pipe in two and remove the burss from the pie and slide the couling or tee into place. These fittings don't require glue and one type snaps into place while another using compressionto seal the fitting. Check for leaks on your repair. Give the area a couple of days to dry out and then take some pipe insulation and cover this area of piping. You will also want to carry some duct tape to repair the liner that holds the trailer insulation up as well. Thanks for using Fix Ya.
Mar 25, 2009 | Plumbing
716 people viewed this tip
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
