Tip & How-To about Computers & Internet
HIDDEN FILES DUE TO VIRUS ACTIVITY
Some virus make the contents of the drive hidden, thats why user can't see the files. This can be fixed and data would be available to you. However, there are number of steps involved.
It is suggested that go to FOLDER OPTIONS - and select 'SHOW HIDDEN FILES & FOLDERS' and uncheck/ Deselect 'HIDE PROTECTED SYSTEM FILES'.
It would show the hidden files/ folders, if the system not infected Otherwise, from the clean/ virus free system you can see your data and copy all the required files/data. Select the required files and right-click and change the properties of the file by un-checking the hidden attribute. Please note that you can not change the properties (hidden attribute of the files) if the files are marked as system files. To change the attribute of such folders you can download and use iReset. Just select the file or folder and its just as easy to drag and drop to reset all attributes and make the files visible again.(Note that you can reset one folder or file at a time)
Also, make sure that you have a good antivirus installed and its updated. Scan your system and clean it.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Computers & Internet Logo
i have a problem with my samsung portable hard drive, it caught a virus and i can no longer access my files. it shows nothing yet when i check properties it says that my files are still there, what can i do about this? i have samsung s2 portable 1 TB
It is due to virus activity. Some virus make the contents of the drive hidden, thats why user can't see the files. This can be fixed and data would be available to you. However, there are number of steps involved.
It would show the hidden files/ folders, if the system not infected Otherwise, from the clean/ virus free system you can see your data and copy all the required files/data. Select the required files and right-click and change the properties of the file by un-checking the hidden attribute. Please note that you can not change the properties (hidden attribute of the files) if the files are marked as system files. To change the attribute of such folders you can download and use iReset. Just drag the files/ folder to the iReset and it would change the folder attributes to normal and you would be able to view the files normally.
Let me know if any further clarification/ assistance is required.
CreativeTECH
Jul 20, 2011 | Samsung S2 Portable External HXMU010EAG32...
how to copy mpeg file to pendrive. when i am trying to copy 5.58 gb file to 16 gb pen drive it shows drive is full
I think it could be due to virus activity. Some virus make the contents of the drive hidden, thats why user can't see the files and the space available for use is less than the capacity.
It is suggested that go to FOLDER OPTIONS - and seclect SHOW HIDDEN FILES. It may show the hidden files. Otherwise, if you dont have any vital data on the drive, just format it. Make sure you backup all your data and verify it before formatting the drive. Hope this would fix the issue and you would be able to enjoy the full capacity of the disk
Let me know if any further clarification is required. Hope this helps! Dont forget to rate the solution!!
CreativeTECH
Feb 15, 2011 | Electronics - Others
I'm unable to find some important data stored in my Sandisk micro cruzer. I'm not sure if I accidently deleted it or if it is corrupted. Please suggest if there is a way to recover the files.
If the pen drive is working, the data is there and can be recovered. I think it could be due to virus activity. Some virus make the contents of the drive hidden, thats why user can't see the files and the space available for use is less than the capacity.
It is suggested that go to FOLDER OPTIONS - and select SHOW HIDDEN FILES. It may show the hidden files. Otherwise, you can use any data recovery program to recover the data. Please not that you should not sav/write any data to avoid overwriting the existing data.
Hope this helps!
CreativeTECH
Feb 14, 2011 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Good morning, I have a 16gb memory stick, having deleted all files it still show as 11gb used and only 5gb remaining, can you offer any advice. many thanks simon
It is suggested that go to FOLDER OPTIONS - and seclect SHOW HIDDEN FILES. It may show the hidden files. Otherwise, if you dont have any vital data on the drive, just format it. Hope this would fix the issue and you would be able to enjoy the full capacity of the disk
CreativeTECH
Jan 13, 2011 | Verbatim STORE-N-GO (95312) 8 GB Hard...
My 16GB USB flash drive is completely empty, but its properties indicate that 14.6GB of space are in use and only 319MB are available. It has worked appropriately for a long time until now. I am now unable to put any large files onto the drive. How can this be fixed?
CreativeTECH
Nov 30, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
275 people viewed this tip
David Payne
David Payne
