Tip & How-To about Computers & Internet
Spped up your PC registry
More seriously, these errors could cause the crippling of your Pc In the event you don't resolve these difficulties. Yet another cause could be that there was a dll that was shared by many applications as well as the reference was placed on the When you have more programs installed in your pc then it may become slow, to fast up your pc use this Regcure application. Regcure software Reviews is a software to clean up the registry of your computer. Guidelines On Making Your Computer Quicker. Published June 3, 2011 ' By Icabod Lucas Xavier. If you feel that your computer has been running slower and slower lately, then you've come to the right place. Many people believe in something called "processor If you don't mind paying for a solution, you can some utility software that will both remove all the spyware and adware from your computer as well as clean up your registry. That way you'll get the fastest computer A lot of the time a simple reboot or removal of new hardware will resolve this issue and the computer will be back up and running. In the event that it is a bit more complicated then the computer will not load and the only way in is safe mode. Austin Porter managed to fix all his PC's errors by downloading a top Registry Cleaner!
Download it from here--http://www.review-best.com/registry-cleaner-download.htm
thanks for rating
Computers & Internet Logo
unexpected shutdown
This could be caused by a card failure, ram failure or even if you installed a software and it had drivers for the wrong operating system. If you allowed microsoft update to update your motherboard drivers or allowed a driver software to do so... they can make mistakes and cripple your computer. Go to safe mode and delete the bad driver or uninstall the last software. Try removing all but one ram etc. Listen for error beeps that tell you that something hardware related is failing. Check the event viewer to see what software or virus may be causing problems etc.
Jan 26, 2013 | Cooking
Results for: Microsoft Product: Windows Operating System; Version: 6.1.7600.16385; Event ID: 10111; Event Source: Microsoft-Windows-DriverFrameworks-UserMode Hi there, I found out after many screen freezing, in the Event Viewer that I have driver issue w/ the DriverFrameworks-UserMode Event ID 10111 Critical Level How can I fix that, please?
There is severe corruption in the kernel (the core files) of your OS and the drivers are no longer loaded. Since you don't know what caused (probably some bad drivers since this motherboard is too old and doesn't have the correct Win 7 ones) it the only sure way to resolve it is to perform a full reinstall of XP.
May 09, 2011 | EliteGroup P4VMM2 Motherboard
I am trying to make a copy of a dvd that I made and am having difficulty. I originally got a 204 error and now it is saying ""No Writers Enabled!" How do I fix this... I have a huge deadline to get this copied.
this error is a registry problem
click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will ((see errors in red)) you will no what exactly what the error was and at what time it occured you might be able to uninstall then reinstall some of these files/software or only if you don
Apr 04, 2011 | Computers & Internet
can not even use restore disks
from microsoft below ....
Bug check 0x50 usually occurs after the installation of faulty hardware or in the event of failure of installed hardware (usually related to defective RAM, be it main memory, L2 RAM cache, or video RAM).
Another common cause is the installation of a faulty system service.
Antivirus software can also trigger this error, as can a corrupted NTFS volume.
Resolving the Problem Resolving a faulty hardware problem: If hardware has been added to the system recently, remove it to see if the error recurs. If existing hardware has failed, remove or replace the faulty component. You should run hardware diagnostics supplied by the system manufacturer. For details on these procedures, see the owner's manual for your computer.
Resolving a faulty system service problem: Disable the service and confirm that this resolves the error. If so, contact the manufacturer of the system service about a possible update. If the error occurs during system startup, restart your computer, and press F8 at the character-mode menu that displays the operating system choices. At the resulting Windows Advanced Options menu, choose the Last Known Good Configuration option. This option is most effective when only one driver or service is added at a time.
Resolving an antivirus software problem: Disable the program and confirm that this resolves the error. If it does, contact the manufacturer of the program about a possible update.
Resolving a corrupted NTFS volume problem: Run Chkdsk /f /r to detect and repair disk errors. You must restart the system before the disk scan begins on a system partition. If the hard disk is SCSI, check for problems between the SCSI controller and the disk.
Finally, check the System Log in Event Viewer for additional error messages that might help pinpoint the device or driver that is causing the error. Disabling memory caching of the BIOS might also resolve it.
Sep 23, 2008 | Gateway 7405GX Notebook
207 people viewed this tip
David Payne
David Payne
