Tip & How-To about Computers & Internet
Video Conversion between WMV and 3GP
3GP is a multimedia container format for 3G UMTS multimedia services. No matter how popular it is, 3GP format can not be compatible with all desktop applications in fact. If you want to convert 3gp to wmv with lossless quality, you should have a right 3GP to WMV Converterto work for you. While, If you have a lot of WMV files and want to play them onyour mobile phones, the very first thing is to convert WMV to 3GP and transferto your cell phone. So a professional video converter that support videoconversion between wmv and 3gp is necessary for you. WondershareVideo Converter Platinum would be a right solution for you . It can act as wmv to 3gp converter that converts from WMV to 3GP easily and fast, and also convertalmost any video with WMV extension. It is also a universal video converterthat provides excellent support to convert 3gp to wmv, 3gp to avi , convert avito flv, convert mp4 to mpeg , mp4 to mkv, convert wmv to flash, wmv to m4v, etc. Following isstep by step guide for conversion. Step 1: Import Files.Run the program. Click"File" option or icon to load WMV files (3GPfiles) you want to convert. Step 2: Choose Output Format. Click"Profile" to set 3GP (WMV) as output format from "CommonVideo" at "Format" section. Step 3: Start Conversion . Click"Start" button to start conversion.Withthis professional video converter, you can not only complete video conversioneasily. This software not only support video conversion between any videoformat, but has advanced options which allows you to set bitrate, framerate,frame , aspect ratio, also crop or pad black strips at outer part of video.You can have a good try!
Computers & Internet Logo
video call faild.what can i do
From http://www-support-downloads.sonymobile.com/k770/userguide_EN_K770.pdf it says :
Both the caller and the receiver of a video call NEED a subscription that supports the 3G (UMTS) service and you need to be within range of a 3G (UMTS) network. 3G (UMTS) service is available when appears on the screen....see Pg 20 of the PDF manual.
May 15, 2013 | Sony Ericsson K770i Purple 3G Camera...
i ve a nokia 2730 classic model ...m using airtel service... when i set umts mode there is no network coverage
This probable if your Network does not have 3G/UMTS coverage in that specific area.
I would set your phone so that it will automatically select 2G or 3G network services (e.g. often referred to as Dual-mode) so that if 3G/UMTS is available and has the best coverage/signal, it will automatically be selected. Setting UMTS coverage only would be very restrictive in many area as the signal is usually weaker (especially in Buildings).
Hope it helps!
Sep 24, 2011 | Nokia 2730 Cell Phone
MY PHONE IS NOT ABLE TO PLAY VIDEO DOWNLOADED FROM MY PC
downoad 3gp or mp4 videos ur phone does'nt play wmv or mpg videos
Jul 12, 2009 | Cell Phones
334 people viewed this tip
David Payne
David Payne
