Tip & How-To about Televison & Video
Samsung LN32A330 TV power up problem
Red LED is on but will not power up. Look for bad caps with domed tops, should repalce all 7 caps (blue marking) at the same time. By Bud Martin
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Televison & Video Logo
set not working cocdition only red &green led on
This sounds like a very common issue.
If set is hard to turn on (takes several tries)but will eventually turn on hereis what my guess would be.
Every set has a standby power supplythat is running 7/24 if the set is plugged in and it supplies voltage to theremote circuit that turn on the main power supply for the tv and hence turn theset on.
This is an area where companies cut corners by using lower rated voltage caps.By this I mean Standby usually provides under 10 volts to trigger the seton----what they do is use filter caps rated at say 10 volts max in a circuitwith 9 volts (example)=with the standby on all the time the filter caps(electrolytic caps) dry out and fail.
The problem usually begins where you have to turn set on or or two times andgradually gets worse--takes longer and more tries to get it to come up.
Once on it will stay on until turned off for a period of time.
The caps will begin to work better (regain some of thecapacitance) as they get hot--hence one it is on it will seem ok.
The beauty of this problem is most of themhappen when set is a year or two old (no warranty) and all you have to do islook at the top to locate bad ones.
They are generally black or blue and round and vary in --they have twoconnections each--a + for positive and a - for negative--not unlike a batterywhich in a way they are. The + and - are marked on top and bottom of most boards.
They are easy to replace and not expensive parts.
The tops are silverand metal looking with creases on top and if bad they will be puffed up ontop---tops must be perfectly flat with no brown material leaking top or bottom.
If this is your problem once you id them (make a drawing) you can begin.
Here is the critical part---on each cap is also marked the value like 220uf 10vdc---220 micro farad at 10 volts maximum.
If you find for example 6 puffed up and all are 10 vdc replace them with thesame value capacitance (like the 220 uf) but go up to at least in this case(from 10 volts) to a 16 or higher rated voltage cap.
The only issue is when you go up in voltage rated value the cap is larger sosometimes there is an issue of physical space for the replacement on the boardto fit them in.
The reason they cheapen these sets in this way is if 10 caps and you make25,000 sets there is a considerable savings in parts cost.
They do not care as long as it lasts past the usual one year parts warranty.
I have taken the time to be long winded because this really sounds like it maybe the problem you have.
See attached photo of a typical cap and if you have questions or need advicelet me know.4_2_2012_3_52_52_pm.jpg
Apr 02, 2012 | Televison & Video
on powering the monitor, power on led glow and goes off after 2 seconds
Look for bad caps with domed tops in the power supply, see example here: http://s807.photobucket.com/albums/yy352/budm/LG/LG%20L1751S/
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 20, 2011 | LG Flatron L1750S 17" LCD Monitor
no power
Look for bad caps with domed tops, repalce them in a set not just the bad one.
See pictures here: http://s807.photobucket.com/albums/yy352/budm/SAMSUNG/Samsung%20LN32A330/
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Jun 10, 2011 | Samsung LN32A330 32 in. LCD TV
tv will not turn on ,i hit the power button the power light goes red then blue then back to red an thats it..
You need to inspect the power supply module, look for blown fuse, bad caps with domed tops, DC output voltages.
Check www.shopjimmy.com to see what the boards look like.
Learn about fixing TV here;
Mar 24, 2011 | Polaroid FLM-3734B 37 in. LCD HDTV
turned it on and got a brief start of light up then nothing. the led power indicator changes from red to blue and back but nothing else happens
you have a bad cap in the power supply this capacitor will have a domed top on it they are shaped like little can and the domed top is from over heating and venting the value of the part is written on the side
Dec 02, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
2,020 people viewed this tip
Top Televison & Video Experts
