Tip & How-To about Saeco Vienna De Luxe Espresso Machine
Proper way to descale an espresso machine.
Hi
I have seen all ways to descale espresso machines on this and other sites and most are wrong!
Never leave the machine heating while the descaler is in the boiler. It's OK for a few seconds but never for minutes or hours. It will turn your seals hard as a rock and the machine will start leaking. If your machine is leaking you probably left your machine on while it was descaling. Factory programs, if used do not turn the boilers on in the descale mode for this very reason.
If your machine has a factory descale mode, use it. All factory descaling programs use the flow meter to regulate the descaling. The flow meter tells the computer how much water has gone through the boiler. when the machine is out of water the flow meter will stop turning and the computer knows the machine has used up all the descaler, and it will want to be rinsed. Remember the pump has to stop on its own for the computer to know it's done! Again the flow meter will tell the computer it is rinsing and when it is again out of fresh water it will tell the computer it is done rinsing and the descaling message or light will disappear. Remember the pump has to stop on its own for the computer to know it's done! It may say descale on some computers and there is a program for resetting the descale. It's in your menu as "Reset Descale". Choose "Yes" and push the menu button to lock. It's all regulated by your water hardness. I have mine set on 4 and my water is very good. I have over 20,000 drinks, and the original boiler. Saeco(Starbucks) Barista Digital.
This method can be used on any espresso machine.
1. Remove the water tank and fill half way with fresh water.
2. Mix your descaling powder (Citric Acid or Durgol Never use Vinegar) in a glass of warm water. When dissolved pour into water tank.
3. Open steam knob. Have a large bowl under the wand to catch the water expelled from wand.
4. Turn on machine (automatics will cycle then start pumping water) Regular espresso machines you will need to turn on the brew button.
5. When the pump has expelled about 8 ozs through the steam wand turn off only the power button. Leave the other buttons and knobs alone.
6. Wait about 10 to 15 minutes for the descaler to work, then turn the power button on and run another 8 ozs through the wand and turn off the power button.
7. Repeat step 6 until the water tank is empty. (machines that have magnets in the water tank will not let you pump the water tank dry but they have programs built in to use that will)
8. Once the tank of descaler is empty, rinse out and fill with fresh water.
9. Open steam knob and run the complete tank of fresh water through the boiler without stopping, and once its complete refill with fresh water and your ready to go.
Saeco Vienna De Luxe Espresso Machine Logo
my romeo nespresso wont leave the descaling mode
"DESCALING" is not a "mode." When the display says "DESCALING," it means that it needs descaling. Follow the directions in your instruction manual.
Jul 20, 2014 | Nespresso Romeo E350 Espresso Machine
what is wrong with my silvia? No coffee or water, but steam ok. Loud burring noise
Hi There,
Your coffee group is blocked, with lime or coffee oils.
Try descaling 1st Pulycaf coffee machine descaler . You will find descaler and cleaner in this rancilio silvia kit. Rancilio Silvia gasket kit . Descaling should be done every 3 months or so.
If the descaler does not work - you may have to remove the solenoid valve and descale that - not an easy fix. Takes 20 min.
May 29, 2014 | Rancilio Silvia Espresso Machine
My Keurig does not dispense enough water for any of the settings. Is there something I an doing wrong or that I can fix. Thanks
Hello Gajaxson,
I understand that your coffee maker/Espresso machine is not putting out enough water when you are brewing. This is a common occurrence when the machine needs to be descaled.
There are many different ways to descale coffee/espresso machines and some have cycles built in that you have to add the solution and push a button. Would please post me a model I will check with and see if the manufacture has any suggestions on how to descale your machine. Also if you still have the owners manual it will show you how to descale your machine.
It is recommended that you descale your machine at-least once every six months for moderate use and once every three months for heavy use.
Thank you for choosing FixYa.com
Justin
Mar 13, 2011 | Keurig Coffee Makers & Espresso Machines
got an old saeco magic comfort 7/8 years old -
bye a good coffee descaler not vinager follow instruction on it normally fill the water tank leave room for the descaler start the machine open side valve leave it running for 15 second turn it off let it site for 10 to 15 minute after open valve for 30 second let it site for 10 minute and open valve repeat untill empty tank after clean water tank very good that descaler is acid nasty stuff after fill the water tank full of water start machine open side valve empty water tank that its good luck pierre p.s it take a while do descale good but worth it
Jan 02, 2009 | Saeco Magic Comfort Plus Espresso Machine
expresso machine
descaling gonna improved the pressure = stronger coffee and clean the inner boiler =warmer coffee but use descaler only not vinegar descaler melt calcium vinegar remove some calcium in littlt piece 1 part descaler 1 part water fill the water container open valve for a few second close it leave it for 15 minute and repeat untill empty after rince very good that stuff is corosif
THANKS FOR USING FIXYA
FROM MONTREAL CANADA PIERRE
Feb 18, 2008 | DeLonghi BAR 14 Espresso Machine
1,834 people viewed this tip
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
