Tip & How-To about Office Equipment & Supplies
How to Refill Hewlett Packard, HP Cartridges
Works With 21,22,27,28,56,57,58,74,75,60b,60c,92,93,94,95,96,97,98,99,100,901b,901c
To refill a HP Cartridge the cartridge must be directly from the printer, not one that has been out for two weeks or more as it might not work.
Full Printable instructions with pictures are Downloadable from here for free.http://www.ziddu.com/download/15223497/HPCartridgeRefillInstructions.pdf.html
  1. To Start simply remove the label from the top of the cartridge.There a five holes on the top of the cartridge (see image in download)
  2. Using your 10ml syringe and 19 gauge tip inject the correct colour into the correct hole.
  3. When the ink is visible in the top, withdraw approx .25ml of ink out to ensure you have not over-saturated the sponge.
  4. Repeat for each colour, For black cartridges simply fill it from the top hole.
  5. let it sit for 5 Mins to ensure there are no leaks and replace in the printer.
This method will save you plenty of money and if done correctly the cartridge can last 10 plus refills.
Happy Printing
RegardsGM
i don't know how to refill?
Refilling HP color printer ink cartridges saves money and time spent running to the store to find the right ink cartridge, which sometimes is out of stock. By having the refill kits for the HP ink cartridge, you can just refill the cartridge when the ink runs out. The refilling process is easy to do and anyone can do it in a few minutes. The ink kits come with directions and all the colors one will need to refill the ink cartridge.
1.Place a piece of paper towel on a flat surface. Remove the empty ink cartridge from the printer. To do this, open the cover and wait for the ink dispenser to move the ink to the open door. Lift up the tap that holds the ink cartridge in place and pull out the cartridge. Push the tap holder back down and close the cover.
2.Place the ink cartridge on the paper towel. Gather the ink refilling kit together with directions and place the ink jars on the paper towel along with the syringe needle.
3.Find the indents on the top of the empty ink cartridge. Poke these holes open with the pen. Sit the cartridge down and open the ink containers. The colors are yellow, cyan and magenta.
4.Read the directions to see where each color goes in the ink cartridge. Insert the syringe needle into the ink container and raise the stopper up until you have the recommended amount of ink to fill into the particular hole.
5.Insert the needle into the hole on the ink cartridge and slowly dispense it into the cartridge. Remember to go slow with this step. If you see the ink oozing out, stop filling and wipe with a paper towel.
6.Cover the holes with the tabs that come in the refill kit or you can use tape. Make sure the hole is sealed to prevent spilling or the ink drying up. Then replace the ink cartridge back into the holder in the printer.
I hope you find it very helpful. Thank you for using fixya.
Aug 22, 2011 | HP PSC 1315 All-In-One InkJet Printer
how to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
instructions on how to refill an hp920xl printer cartridge
http://h10032.www1.hp.com/ctg/Manual/c01669504.pdf
Download the above manual.....go to page no. 144.
It has brief direction to reset ink level.
Sep 17, 2009 | HP Officejet 6500 Wireless All-in-One...
Help me replace the ink cartridge on my photosmart copier/printer
Step 1: Turn printer on -- open front door.
Step 2: Tilt cartridge down in front and remove cartridge.
Step 4: Refill cartridge with ink per instructions on refill kit.
Step 5: Reinstall cartridge by reverse of step 2, then 1.
Works for me -- I refill 6 or more times before replacing the
cartridge.
HP 1401 PSC
Aug 29, 2008 | HP Office Equipment & Supplies
ink cartridge refills
hi,.
   the thickness of the ink in the genuine hp cartridge is different from the refill ink. it will never match. so thats it. try with a genuine hp cartridge and  check whether the printer works fine. else it might be the problem with the printer.
May 11, 2008 | HP Officejet Pro L7680 All-In-One Printer
819 people viewed this tip
jasbo
jasbo
