Tip & How-To about Washing Machines
LG Washing Machine UE Error Code Solutions
An UE Error Code is indicative of a "Unbalanced Error". This indicates that the drum is not spinning in a smooth rotation. It may be necessary to rearrange the load in the drum.
Washing Machines Logo
error code VE or UE
Is it LG?
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 01, 2011 | Washing Machines
What does UE mean on a 4kg LG washer drier??
Hi!! UE Error Code is indicative of a "Unbalanced Error". This indicates that the drum is not spinning in a smooth rotation. It may be necessary to rearrange the load in the drum.
Don't forget to rate this post!!
Sep 15, 2010 | Washing Machines
Goes Through Wash Cycles Empty Or Full Stops At Spin And Says UE About 4 Minutes Before End
An UE Error Code is indicative of a “Unbalanced Error”.
Thank You
Sep 08, 2010 | LG WM1814CW Front Load Washer
Error reading
If you tried out all things and it did not work,
then I would say you have a bad motor. The motor has a tach in it that tells the control board if the load is balanced. If the tach is bad in the motor then it will always think the load is unbalanced.
Hope i helped you.
Sep 06, 2009 | LG WD-1045FH Front Load Washer
LG WM 14316FD washing machine
An UE Error Code is indicative of a “Unbalanced Error”. This indicates that the drum is not spinning in a smooth rotation. It may be necessary to rearrange the load in the drum. I found this answer on the lg web site.
Dec 01, 2007 | LG Washing Machines
1,149 people viewed this tip
Top Washing Machines Experts
