Tip & How-To about Nintendo Wii Console
Nintendo Wii Error Code 52030 The most likely cause of error 52030 is that the router securityinformation was entered incorrectly on your Wii or that your router is unableto assign an IP address to the Wii. If this problem just started, and your Wii was working before, then tryto power cycle your equipment. Turn off the modem, router and Wii. After10 seconds turn on the Modem, after 30 seconds turn on your router, and after30 seconds turn on the Wii. If this does not work then continue below, Make sure your wireless networksecurity password and security typeis entered into your Nintendo Wii correctly. You can go into your routersconfiguration page to view the security key and view security type. If needed,you can change these. On most routers, you can access the configuration page byopening your Internet Browser and going to the router ip address(gatewayaddress) 192.168.1.1 This address may vary from router to router. Once you goto this address you should get a login page. Login and then go to your Wirelesssettings page to view the settings you need for your Wii. Once you verify thesecurity key and type, input these settings into your Wii and test theconnection. Click here for my tech article on how to configureinternet settings on the Nintendo Wii. Tip - To view your gateway address in Windows do the following, Go to Start > Run and in the run box type "command" or"cmd". A black DOS window should open. In this window type"ipconfig /all" you should now see a gateway address. -Most home networks will use DCHP. What is DCHP? This is Dynamic HostConfiguration Protocol. In short, it means your router or server will assign IP and DNSaddresses out automatically, with no intervention needed from you. If you aremanually using settings(not using DCHP) you will need to assign an IP/DNSaddress to your Wii. To get to the Wii settings to input an IP address and DNS address, dothe following, Access the Wii System settings and select "Internet" from Page 2. Select "Connection Settings" and choose the connection file youcurrently use (will have a red border around it). Select "Change Settings," and click the right blue arrow twice toreach "Auto-Obtain IP Address." Click on "No" and select "Advanced Settings." Enter in your IP address, DNS address and subnet mask information. A Wii connection test should confirm the internet is now working. Again, mosthome networks use DCHP so you may not need to set an IP address. -Interference can also cause this issue. Try and make sure there are nowireless devices around the Wii and router and the Wii is in an open areawithout devices blocking it. -Change your router's channel setting to 1 or 11. By default, mostrouters broadcast on channel 6, which overlaps with other channels and may beweaker. If you are still having trouble, you may want to reach out to NintendoTechnical Support at 1-800-255-3700 -G33k Check out some of my other tech articles! Nintendo Wii Error Code 51031 Tuneup utilities prefetch data deleted Computer freezes, computer stuck How to disable/enable Microsoft Windows startup programs Garmin GPS - stuck , not updating, no signal problems Keywords Nintendo Wii Error Code 52030, Wii error code 52030, Wii 52030, Nintendo Wiiinternet issues, Wii internet, Nintendo Wii internet
Nintendo Wii Console Logo
can not connect to internet on my wii error code 52030
It's possible that the wireless security pass code for your home network may have been changed or is entered incorrectly on the Wii console
Jun 04, 2012 | Nintendo Wii Console
How do I fix error code 52030
Click Here for More Information, on Nintendo.com
Error Code 52030:
Unable to connect to your wireless network
Likely cause: It appears that the security settings entered into the Wii console are not the same as what your wireless router is set to allow, or your router is not able to assign the Wii an IP address.
How to fix: Make sure the security key and security type are entered into the Wii exactly as they appear in your router's settings; manually assign an IP address to the Wii.
Apr 30, 2012 | Nintendo Video Game Consoles & Games
error 52030
Error code 52030 means that you have entered the security settings for a router incorrectly. This site guide you through fixing the error.
May 31, 2011 | Nintendo Wii Console
I have netflicks and is has quit working, i have a error code 52030
That error code means that your settings for your router are incorrect. Try to re-enter your settings and see if that fixes the issue.
May 01, 2011 | Nintendo Wii Console
Wii will not conect to the internet today, we have not had a problem before today. When I test it it shows an error code of 52030.
The following information was taken directly from Nintendo's website about error code 52030. I have included a link at the bottom directly to the page from which I got this information. If you click the link, there will be a step by step guide on fixing the error:
Error 52030
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=52030&system=Wii&locale=en_US&action2.x=29&action2.y=19
Apr 07, 2011 | Nintendo Wii Console
5,917 people viewed this tip
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
