Tip & How-To about Watches
How to shortcut watch battery.
There are plenty of watches around where you can find writing Shortcut battery and AC. Some writings explain how many times you have to shortcut and for how long as well. Make sure you read exactly what it says and do exactly what it says. Shortcut is needed to restore all watch settings and to make all functions work properly. Shortcut must be done right after replacing watch battery, before any settings. Please note - if you are not quick enough with battery replacement, all previous data from watch memory will be lost. Usual max time for battery replacement is 3 minutes. So, when you decide to replace battery, do it as fast as you can, just make sure do not damage the watch in a rush. When the new battery is in place and in right position, get an eyeglass or magnifying glass and carefully examine watch movement all way around. You should find brass/silver coloured contact with letters AC next to it or even on it. This is exact point for shortcut. Take fine pointed tweezers and touch with one pointed end battery's + and with another end AC contact and hold for 3 seconds. If writing in the watch says Shortcut twice, then do it twice for 3 seconds. When shortcut is done, your watch is ready for use and you can set the desired time, date, month and so on.Hope this will help for everyone who want's to save few quid on watch repairer charges.
Watches Logo
I just replaced the battery in my Nooka Zub Zen-V, now the display just flashes nonstop. I have tried pressing all four buttons for up to 30 sec. and the entire display turns on but when i release any of the buttons it just goes back to flashing.
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs.Shortcut battery with AC contact. AC can be found on the sides of watchlb_icon1.png movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs...
Oct 16, 2013 | Nooka ZOT V - White Face - White Strap...
i have this stopwatch called Flinn Scientific and it has all the batteries and all but it wont turn on. Flinn Scientific Sport Timer AP 1572
http://support.casio.com/en/manual/009/qw1572.pdfhttp://support.casio.com/en/manual/009/qw1572.pdf
Oct 05, 2013 | Casio AMW705B 1AV Hunting watch
Casio Telememo 30 I need to change my battery again. I did this once before and seem to remember having to short the watch using a hole in the movement inside the casing. I can't find a source for that procedure anymore and, as I am in the military overseas, can not just pop put to the local watch shop.
There are plenty of watches around where you can find writing Shortcut battery and AC. Some writings explain how many times you have to shortcut and for how long as well. Make sure you read exactly what it says and do exactly what it says. Shortcut is needed to restore all watch settings and to make all functions work properly. Shortcut must be done right after replacing watch battery, before any settings. Please note - if you are not quick enough with battery replacement, all previous data from watch memory will be lost. Usual max time for battery replacement is 3 minutes. So, when you decide to replace battery, do it as fast as you can, just make sure do not damage the watch in a rush. When the new battery is in place and in right position, get an eyeglass or magnifying glass and carefully examine watch movement all way around. You should find brass/silver coloured contact with letters AC next to it or even on it. This is exact point for shortcut. Take fine pointed tweezers and touch with one pointed end battery's + and with another end AC contact and hold for 3 seconds. If writing in the watch says Shortcut twice, then do it twice for 3 seconds. When shortcut is done, your watch is ready for use and you can set the desired time, date, month and so on.Hope this will help for everyone who want's to save few quid on watch repairer charges.There are plenty of watches around where you can find writing Shortcut battery and AC. Some writings explain how many times you have to shortcut and for how long as well. Make sure you read exactly what it says and do exactly what it says. Shortcut is needed to restore all watch settings and to make all functions work properly. Shortcut must be done right after replacing watch battery, before any settings. Please note - if you are not quick enough with battery replacement, all previous data from watch memory will be lost. Usual max time for battery replacement is 3 minutes. So, when you decide to replace battery, do it as fast as you can, just make sure do not damage the watch in a rush. When the new battery is in place and in right position, get an eyeglass or magnifying glass and carefully examine watch movement all way around. You should find brass/silver coloured contact with letters AC next to it or even on it. This is exact point for shortcut. Take fine pointed tweezers and touch with one pointed end battery's + and with another end AC contact and hold for 3 seconds. If writing in the watch says Shortcut twice, then do it twice for 3 seconds. When shortcut is done, your watch is ready for use and you can set the desired time, date, month and so on.Hope this will help for everyone who want's to save few quid on watch repairer charges..And keep up the good work you are doing for the country...
Sep 30, 2013 | Casio DB360G-9A 30 Pages Telememo Watch
bench bc0051 time set instuctions
May 21, 2013 | Watches
Casio MDV-701 watch, analog time does not work after batteries changed
you need to do this Shortcut the battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs
Feb 17, 2013 | Watches
1,875 people viewed this tip
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
