Tip & How-To about Computers & Internet
How to find serial numbers, lost serial numbers, how to obtain serial numbers, serial keys
How to find a serial number for software/hardware
Use the information in this article at your own risk. Always keep your computer firewall and virus programs up to date and activated.
Serial numbers
for software are usually needed to activate or verify the software was purchased from the vendor, to obtain updates and to install the software. Sometimes, you can misplace or be unable to locate the serial number.There are a couple of ways to obtain a serial number for software, some are legal and others illegal. I will go over common methods to help you obtain the serial numbers.
-A easy and legal way to obtain software serial numbers is simply by purchasing the software. A lot of the times when you purchase the software directly from a website, the website will provide you with the serial either directly on the purchase confirmation page or through an email. If you buy the software from a store, the serial number is usually located on the disc package or case. If you lost this serial number, you can try contacting the technical/customer support for the product and they may be able to help you obtain a new one. An alternate method is to obtain a product key from online or through a torrent program. This is usually illegal and sometimes lead to a virus if you are not careful. I will explain more below.
-In some cases you can obtain a serial key or a crack program for the software product. A crack program basically provides you with a serial number or it can circumvent the software authentication process(bypass activation). Be warned, doing this is usually illegal and if you are not careful when downloading programs or visiting websites, you can potentially get a virus.
An example of how to do this is to use a torrent site. On a torrent site, you can download a file called a torrent. This torrent basically is a pointer to all the computers who have this certain file you wish to download. You then use a torrent down loader like Utorrent to open the torrent and download the file. A website you can visit to look at torrents is piratebay.org.Go to piratebay, search for the file you want to download and then save it to your computer(desktop is easiest). Then open the torrent file in Utorrent. It should start to download the file. I would advise you also download a program called PeerBlock and have that running in the background as you download files. PeerBlock keeps a list of IP addresses(computers) who's intent is to track and prosecute people who download files illegally.
By searching, you may find a crack program you can use to crack the software in question, and in some cases find a "key generator". A key generator usually provides you with a serial key to use.
-If you are looking for a serial key for hardware like a laptop or MP3 player, this is usually located on a bar-code sticker on the back, or sometimes in the battery compartment. Also, you may be able to find it within the software by turning on the device and going to "help" or "about'.
I hope this article was informative. Thanks for reading.
Regards,
G33k
Keywords
obtain serial key, how to obtain serial key, how to crack serial key, lost serial key, find serial key, find software serial key, find software serial, crack software serial key
Computers & Internet Logo
I need nero 11 serial number
If you use free stuff like this, you chance getting a virus, malware, or spyware attached to it. Why risk it?
Dec 28, 2013 | Ahead Software Nero 6 Ultra Edition...
when i start my pc today, i had stop 0x0000007b (0xf9e48528 0xc0000034 0x00000000 0x00000000) i try with chkdsk /r end fixboot but no result.
When you start your computer, you may receive one of the following error messages:
  • STOP: 0x0000007B (parameter1, parameter2, parameter3, parameter4)
    INACCESSIBLE_BOOT_DEVICE
  • Setup has encountered a fatal error that prevents it from continuing.
    Contact your product support representative for assistance. The following status will assist them in diagnosing the problem.
    (0x4, 0x1, 0, 0)
    Setup cannot continue. Power down or reboot your computer now.
You may also receive a "Stop 0x0000007B" error message during Windows XP Setup when the Setup program restarts during the installation process. When you receive a Stop error while the Setup program is running, you receive the second error message. To troubleshoot this issue, read the following four sections to determine if any one of the issues applies to you. If none of the issues apply to you, use the following general troubleshooting steps at the end of the article. uparrow.gifBack to the top Boot-Sector Viruses You may receive a "Stop 0x0000007B" error message if your computer is infected with a boot-sector virus. If the problem is intermittent and you can start Windows, check your computer for viruses. If you find a virus, also check any floppy disks for viruses before you use them again.
For a list of antivirus software manufacturers, click the following article number to see the article in the Microsoft Knowledge Base: 49500 List of Antivirus Software Vendors Note You may have to use more than one brand of virus-detection software to detect and remove various viruses.
Important If your computer has been infected, it may be open to additional forms of attack. We recommend that you rebuild infected Internet-facing servers by following the guidelines that are published on the CERT Web site. Internet-facing servers are servers that function without a firewall or other protection. It is also a good idea to rebuild any other computers that are at risk because of their proximity to infected computers before you put them back in service.
If a virus has infected your Windows XP-based computer and a virus-detection program cannot remove the virus and repair the system, you must repartition and format your hard disk and reinstall Windows XP. For additional information about partitioning and formatting a hard disk with Windows XP, click the following article number to view the article in the Microsoft Knowledge Base: 313348 How to partition and format a hard disk in Windows XP For more information about how to help protect the boot sector from viruses in Windows XP, click the following article number to view the article in the Microsoft Knowledge Base: 122221 How to protect boot sector from viruses in Windows uparrow.gifBack to the top Device Driver IssuesYou may receive a "Stop 0x0000007B" error message in the following scenarios:
  • A device driver that the computer boot controller needs is not configured to start during the startup process.
  • A device driver that the computer boot controller needs is corrupted.
  • Information in the Windows XP registry (information related to how the device drivers load during startup) is corrupted.
Windows XP requires a miniport driver to communicate with the hard disk controller that is used to start your computer. If Windows XP does not supply a device driver for your controller or if Windows XP is using a corrupted or incompatible driver, you must replace the driver with a valid copy that is compatible with your controller and Windows XP.
During the first phase of the Windows XP installation, Setup displays the following message at the bottom of the screen: Press F6 if you have to install a third-party SCSI or RAID driver. Press F6 and then follow the instructions to install a mass-storage device driver from your Original Equipment Manufacturer (OEM). For additional information about using F6 to load an OEM device driver to support, click the following article number to view the article in the Microsoft Knowledge Base: General Troubleshooting If none of the issues that have been described in this article apply to you, use the following general troubleshooting steps:
  1. If you receive one of these error messages while you are installing Windows XP, update the computer BIOS or obtain Windows XP drivers for your hard disk controller (from the manufacturer of your computer, system board, or hard disk controller), or do both. For information about how to update your computer's BIOS or obtain Windows XP drivers, contact your computer manufacturer. For additional information about the availability of drivers, see the Device Driver Issues section in this article.
    Note: If Windows NT 4.0 or Windows 2000 was installed previously on a mirrored boot partition, see the Other Issues section in this article.
  2. Use the Last Known Good Configuration feature. This may resolve the problem if you recently installed an incompatible device driver for your boot controller. For additional information about using the Last Known Good Configuration feature, click the following article number to view the article in the Microsoft Knowledge Base: 307852 How To start your computer by using the Last Known Good Configuration feature in Windows XP
  3. Use the Repair option with Windows XP Setup. For additional information about repairing Windows XP by using the Setup program, click the following article number to view the article in the Microsoft Knowledge Base: 315341 How to perform an in-place upgrade (reinstallation) of Windows XP
  4. Restore a registry backup. For additional information about restoring a registry backup, click the following article number to view the article in the Microsoft Knowledge Base: 307545 How to recover from a corrupted registry that prevents Windows XP from starting
May 18, 2011 | Computers & Internet
I have download adobe pagemaker 7.0 in online. but i cannot see serial number. How i can download serial number and activate my software?
Go to the following search engine
www.Google.com
and type the following keyword
"adobe pagemaker 7.0 SERIAL NUMBER"
You will get a lot of websites where you can search for the serial number you are looking for.
Please be careful most of this sites are inhabited with Viruses so always keep a good Anti Virus installed on your computer with Virus protection shield turned on.
Good Luck!
Jan 16, 2011 | Computers & Internet
Router Firewall
Not entirely. Hardware firewalls (such as the one in your router) will block incoming connection attempts based on the port they're using, the protocol, and a number of other factors (varied between firewall brands). Some are designed to block only popular attacks (DoS, PoD, crackers on port 80, Telnet connect attempts, etc...) while others will block a larger variety of attacks.
Anyways, software firewalls will block almost all incoming Internet traffic (except for the ones defined in the exceptions) along with almost all outgoing Internet traffic. The only way I find this to be useful is if you're trying to keep some private information private, or if you use that computer to determine if some software is trying to phone home (web beacon, trojan, dialer, etc...).
I really don't see the need for Software firewalls unless you're a hard-core web-surfer and don't care what you click on. If you do like the extra security, perhaps one of the better software firewalls is made by ESET.
I prefer ESET to Symantec's Personal Firewall because Symantec's Firewall on one of my older systems was hijacked by a virus a few years back which allowed the virus unprecedented access to the root of my Operating System. The virus gutted the computer without any alerts from Norton CE or the Firewall.
Anyways, I hope this was the answer you were looking for. If not, please feel free to respond with more details on what you were truly asking. All the best. ;-)
Jan 30, 2009 | Linksys Wireless-G WRT54G Router
856 people viewed this tip
David Payne
David Payne
