Tip & How-To about Apple iPad (16 GB) WiFi Tablet PC
How to Transfer Files to Your iPhone or iPad For Newbies
A friend of mine recently called me, frustrated, because he couldn't figure out how to get PDFs on his iPad. While it's actually a very simple operation once you know how to do it, it's not something that's very obvious to people who are new to iOS (as many iPad users are). Here's a look at the simplest method of transferring files to an iDevice for those who don't yet know how to do it.
The video above will walk you through the process visually, but here are the basic steps you need to follow:
  1. Connect your iPhone, iPod touch, or iPad to iTunes. (You can let it sync if you want, but this isn't necessary.)
  2. Click on your device in the list on the left side of iTunes. (It'll be under the "DEVICES" header.)
  3. Click the "Apps" tab up on top in the main panel of iTunes.
  4. Scroll down to the bottom where you'll find a "File Transfer" section with a list of apps. From that list, choose an app you want to transfer a file to.
  5. Onto the (probably empty) space to the right of the apps list, drag in the file you want to transfer. You can also click "Add..." to browse for the file and choose it. As soon as you've chosen the file, it will transfer to your device. You'll see the progress at the top of the iTunes window. When it's done you can disconnect and your file will be on your device.
Some apps provide additional ways to transfer files that you may prefer, but this is the most straightforward method and it works for every app that supports files. If you'd prefer to transfer over Wi-Fi (or another method), check the app to see if it has other methods. These methods vary from app to app, but most provide instructions so you can learn how to use the various transfer methods. They're worth exploring if you prefer to avoid connecting your device to your computer every time you want to transfer a file.
Apple iPad (16 GB) WiFi Tablet PC Logo
Keyboard shortcuts
Messenger has 5 icons at the bottom of the screen. From left to right,
Recents, which is conversations you have had.
Calls, which is a list of people who have a device you can call,
Groups, which enables you to select a number of friends to message.
People, which is your Contacts directory.
Settings, which allows you to set up your phone number, and various options including Help.
Messenger is part of Facebook, so make not play ball with iPad settings.
Apr 03, 2016 | Tablets & eReaders
I have changed my passward for my iPad and after that have forgotten it. Tried 10 times to guess it but could not succeeded. Finaly the iPad restarted and i lost all my apps and photos. Iz it possible to resore them any way?
Forgot iPhone passcode or iPad passcode? This can be fixed with iTunes actually.
Connect your iPhone to your computer.
In iTunes, select the iPhone in the "Devices" list, then "Summary" at the top of the screen. If iTunes doesn't automatically synchronize your iPhone, do so manually
Click "Check for Update." iTunes tells you if there is a newer version of the iPhone software available.
Click Restore. Follow the onscreen instructions to complete the restore process. When restoring, it is recommended that you backup the iPhone when prompted.
When iOS Setup Assistant asks to set up your iPhone, choose "Restore from iTunes backup."
Select your device in iTunes and choose the most recent backup of your iPhone.
http://www.transfer-iphone-recovery.com/forgot-iphone-passcode.html
Sep 20, 2013 | Apple iPad (16 GB) WiFi Tablet PC
How do I make the new iPad's battery recharge faster?
There are many things you might be doing wrong but slow battery charge is a problem with the new iPad. The battery is actually a lot bigger than the iPad 2 which means it is going to take you much longer to charge.
Use the provided charger and don't charge from your computer. It is almost twice as slow to do it plugged into a computer. Charge it at night to give it the most time to charge as possible. I usually turn it off so programs don't run and slow down the charging speed. Every little bit helps.
I can help you with other things too if you ask.
Mar 27, 2012 | Apple iPad HD
Can't jailbreak ipad1 I don't have a computer iPad is updated with os 501
If you don't have a computer, it is unable to jailbreak your iPad. So try borrow one PC or Mac from your friends. And then if you prefer a simple yet fast solution to jailbreak your iOS device. You can take a try of AutomaticiPhoneUnlockers, it can help jailbreak or unlock as many iPad, iPhones, iPod Touches as you like. Hope this helps! Regards.
Mar 03, 2012 | Apple iPad (16 GB) WiFi Tablet PC
Can u tell me how to install adobe flash player on my iPad to play king.com
Yes, jailbreaking your iPad is the fast solution, and if you prefer a simple yet fast fix to jailbreak your iOS device. You can take a try of AutomaticiPhoneUnlockers, it can help jailbreak or unlock as many iPad, iPhones, iPod Touches as you like. After that you can install any apps on the device.
Dec 30, 2010 | Apple iPad 32 GB WiFi Tablet PC
2,273 people viewed this tip
Top Apple Tablets & eReaders Experts
Virgil Wolter
Level 1 Expert
Aaron Galvan
Level 1 Expert
Yoav Shilon
Yoav Shilon
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
