Tip & How-To about Washing Machines
Whirlpool Washing Machine F20 Error code explained and resolution
"F20" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed.This can be a potential problem with the following:
  1. Check that there are no obstructions to the water entering the machine (faucet setting, clogged screen, kinked hose, etc.)
  2. Remove the top cover and check the resistances of the inlet water valves and and flowmeter.
  3. Check that the flowmeter has been installed properly - with the rounded section vertically oriented.
  4. Check out the drain hose. An improperly installed drain hose can result in 'siphoning' if the drain hose tip is in contact with water (or if a pressure issue exists within the drain). That water may be siphoned out of the hose resulting in this F20 error.
  5. Pull the hose out of the drain pipe and see if the tip is wet.
  6. If so, add more hose. You can do this with PVC pipes.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Washing Machines Logo
stopping mid cycle and showing F20
"F20" is a No Water Detect error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed. This can be a potential problem with the following:
If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
Oct 13, 2014 | Whirlpool Duet GHW9150P Front Load Washer
What does it mean when my duet washer flashes F20?
F20 is a No Water Detect error.
* If you have NO water in the wash tub, check the following:
* If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions: Duet_Service_F20_error
Hope helps.
Sep 24, 2011 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
F20 code
http://www.fixya.com/support/r1491905-f20_error_code_whirlpool_duet_kenmore
http://www.appliancepartspros.com/
Feb 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
what does f20 meam
Hi
Error F 20 means "No Water Detect" error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed.
You'll need to check for the following--
1- Check the Inlet water valve if it is clogged.
2- Make sure water taps are working fine.
3- Check inlet hoses for kinks or clogs.
Jan 04, 2011 | Kenmore Elite 45986 Front Load Washer
570 people viewed this tip
Top Washing Machines Experts
