Tip & How-To about Computers & Internet
Reset and Restore the NETGEAR device to Factory Default Settings
Symptoms:
  • Forgotten/lost password to log into the NETGEAR device
  • Cannot access the NETGEAR device web interface
Resolution:
If you have changed the default password and have forgotten the password, you may need to reset the NETGEAR device to factory default settings.
When a NETGEAR device resets, it goes back to the state when it was new - all information that was entered by hand is lost! Examples include critical things you need to get online, such as ISP username, ISP password, IP addresses, wireless security keys, and ports and services that were opened. It all needs to be re-entered.
So, have your ISP information before resetting the router.
Naturally, if you moved to a new city, or if you bought a used router, the old information in the router may not be of use to you. Contact your ISP if you can't connect any computer directly to the Internet. Then, if there is a connection problem when the router is added, see No Internet Access Through the Router
Reset for most routers with a reset button on the rear panel
Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or 1234. Try these before resetting the router.)
  1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the router configuration was not cleared, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
For DGN2000 / DG834Gv5 Routers
To restore the factory default configuration settings when you do not know the login password or IP address, press both the Wireless button and WPS button on the side of the modem router for 5 seconds.
For FR314, FR318, and FV318
These routers require reloading the firmware in order to recover from a lost password. Download the most recent firmware from NETGEAR's Web site before proceeding. Follow the instructions in the manual.
Computers & Internet Logo
crack password online
Restoring a Netgear Router to Factory Default Settings
Symptoms:
Cannot access the NETGEAR router or access point web interface login screen, or
You have forgotten/lost the password to log into the NETGEAR router or access point (NOTE : This refers to the password required to access the devices administrative interface. If you have forgotten the password required to access the wireless network, you should refer to this article instead).
http://kb.netgear.com/app/answers/detail/a_id/9665/~/restoring-a-netgear-router-to-factory-default-settings
Sep 16, 2013 | NetGear Computers & Internet
can't get my network security key for my netgear wndr3300 wireless router to connect my new laptop too. I have recently moved and re set up the router I have used the install disk that came with and have sevice via hard line and 5ghz but not on 2.4ghz
Symptoms:
May 30, 2011 | Computers & Internet
I need my netgear password
Most of the NETGEAR devices, except ReadyNAS products and Fully Managed switches, have the following default username and password:
  • Username = admin
  • Password = password
    • For older devices, password = 1234
If you have changed the default password and have forgotten it, you will need to reset the NETGEAR device to factory default settings in order to use the default username and password. Click here to learn how to reset the NETGEAR device to factory default settings. Please note: restoring a device to its factory default settings will erase any changes you have saved to the device.
Symptoms:
Click here for video walk through example of how to reset the WGR614v9 router.
Resolution:
For routers with a 9-pin manager port on the rear panel: RT314, RT311, RM356, RT328, RT338, RH340, and RH348
See Updating Router Firmware That Uses a Manager Port.
Here is a small video that shows you how:
http://kbserver.netgear.com/media/flash/training/Troubleshooting/NG_WGR614V9Router_TS_LostPassword.html
Good luck.
Mar 10, 2011 | NetGear WNA1100 Wireless-N 150 USB Adapter...
forgot my security passphase shirleywilt1@gmail.com
Symptoms:
Resolution:
Oct 30, 2010 | NetGear Computers & Internet
cant remember my netgear network key
Reset and Restore the NETGEAR device to Factory Default Settings Problem: var js_3;function initPsDisplay(){js_3 = new PsDisplay({"info":{"controller_name":"PsDisplay","name":"PsDisplay_3","type":"FormField","w_id":3},"attrs":{"label":"","tabindex":"","field_name":"description","cf_id":"","table":"answers","highlight":0},"js":null});js_3.init();}YAHOO.util.Event.onDOMReady(initPsDisplay); Symptoms:
Workaround: var js_4;function initPsDisplay(){js_4 = new PsDisplay({"info":{"controller_name":"PsDisplay","name":"PsDisplay_4","type":"FormField","w_id":4},"attrs":{"label":"","tabindex":"","field_name":"solution","cf_id":"","table":"answers","highlight":0},"js":null});js_4.init();}YAHOO.util.Event.onDOMReady(initPsDisplay); Resolution:
When a NETGEAR device resets, it goes back to the state when it was new — all information that was entered by hand is lost! Examples are critical things you need to get online, such as ISP username, ISP password, IP addresses, wireless security keys, and ports and services that were opened. It all needs to be re-entered.
Hope this helps.......
God Bless.......
Aug 26, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
382 people viewed this tip
David Payne
David Payne
