Tip & How-To about Cell Phones
Delete Contacts Fast Apps Iphone
1. Quickly select and delete multiple contacts
2. Search contacts by name or phone number.
3. Select all contacts on search result at once, (also you can deselect all)
4. With selected list, you can check contacts before deleting them.
5. With Easy Select, you can select name duplicated, no email address, no phone number contacts at once.
6. With number scroll index and sorted list by name, you can fast scroll and find contacts.
DOWNLOAD
Cell Phones Logo
how do I set up speed dialing on my HP Officejet 5740
While "Speed Dialing" or "Speed Dial" is listed in its fax specifications on some sites, it appears to be a mislabeled categorization of its group fax feature as HP's manual makes no other mention of it--save to say, the "fax to multiple numbers" (or multiple recipients) feature. There does not appear to be a speed dial list, but there is a phone book feature for adding contacts (individual numbers) & groups. (The following is detailed in a more explanatory way on pages 65-66 of the user's manual (http://support.hp.com/us-en/product/HP-Officejet-5740-e-All-in-One-Printer-series/6617253/model/6617254/manuals?cc=us&lang=en).
1. From the printer control display, touch Fax.
2. Touch Send Now.
3. Touch the telephone symbol to access its phone book feature.
4. Touch the person symbol for a phone book contact; or touch the multiple person symbol for a group of phone book contacts.
(Note: Contacts should be established before any of these could be added to any group.)
5. Touch + (plus sign) to add a contact/group; or touch the gear symbol (edit) to edit/delete a contact/group.
6. Touch Name.
7. Changes to contacts/groups:
•Adding a contact/group: type the name, & then touch Done.
••Adding a fax number to a contact: Touch Fax Number, enter this contact's fax number, & touch "Create".
••Adding a contact to a group: Touch Number of Members, select all of the contacts to add to this group from this printer's phone book, & touch Select followed by touching "Create".
•Editing: Select the contact/group name, & then touch Done. Then...
••Editing a Contact: touch Fax Number, enter the fax number, & touch Done.
••Editing a Group: touch Number of Members & deselect the contacts to remove from this group or touch + (plus sign) to add contacts to this group. Then touch Done.
•Deleting a contact/group: Select the name, & then touch Delete followed by touching Yes.
Feb 25, 2015 | HP Office Equipment & Supplies
Can you tell me to how to delete contacts on a Samsung M1 360 Thank you
As your using Samsung cellular phone you delete the contacts if you follow this simple steps.Go menu select it after that scroll over to contacts select it after that scroll over to delete option select it after that it will ask to delete all,or one by one you can select according to your wish.There is also another way select menu then scroll over to contacts select it there you will get search there type the name which you saved after that you will get that name there you will be having detail option select that option then scroll over to delete number and select that the number will get delete.Thanks for asking question happy to help .
Jun 15, 2011 | Cell Phones
canton use skype
Reinstall Skype. It should take about 3 or 4 minutes.
May 15, 2011 | Skype IM
my Nokia e63 does not show names of my contacts when they call me on my phone. it only shows their number even though i have saved their contact details in my phone.Same problems are with messages
Probably you have multiple names on the same number in your contacts due to storing contact number more than once, truncation, etc. Use Search Tool facility in Office, search contacts using the number you have problem with. If it found multiple names, choose one you like and delete all the others.
Jul 11, 2010 | Nokia E63 Cell Phone
how to delete phone memory from a nokia 6070
Hi-
To delete all the contacts and the details attached to them from the phone or SIM card memory, select Menu >
Contacts > Delete all contacts > From phone mem. or From SIM card. Confirm with the security code.
To delete a contact, search for the desired contact, and select Options > Delete contact.
To delete a number, text item, or an image attached to the contact, search for the contact, and select Details.
Scroll to the desired detail, and select Options > Delete > Delete number, Delete detail, or Delete image.
Deleting an image from contacts does not delete it from Gallery.
Pls rate as fixya if it helps, THANKS!
Jun 30, 2008 | Nokia 6630 Cellular Phone
135 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
