Tip & How-To about Cell Phones
Cydia first load
Firstly
when cydia initializes the update continues after you
prompted to select a "user profile". There are three patterns to choose:
user (very basic), Hacker (command line), or for developers (filters are not either). This feature allows you to hide the packages the most advanced of us would never use.
Next on the list is the ability to hide entire categories. It's great when you want to hide more technical packages.
Finally
He is the editor of new sources. It's a bit like the installer, except
that's apt sources for Cydia. With this you can add your own
sources as they become available.
Cell Phones Logo
I have a cect n97c and i can't seem to get the settings correct in the the phone to be able to send and receive mms. I've called t-mobile 20 times and they finally told me that i needed to contact the manufacturer. I've tried over the air software updates, they didn't have any cect phone updates. they also had me change the mms settings a ton of different times. i have a data plan which i don't think i even need. it works, the sms works as well, However the MMS doesn't send or recieve. it recieves messages but is unable to download, and when sending an mms it says message failed.
Create Data Account
3. Select Services
4. Select Data Account
5. Select GPRS
6. Choose an empty profile
7. Account Name enter T-Mobile WAP
8. Press Options
9. Press Done
10. APN enter wap.voicestream.com
11. Press Options
12. Press Done
13. User Name >Leave Blank<
14. Password >Leave Blank<
15. Auth. Type choose Normal
16. Press Done
17. Press Save
T-Mobile MMS
Create Profile
3. Select Services
4. Select WAP
5. Select Setting
6. Select Edit Profile
7. Select a profile
8. Choose Edit Profile
9. Rename Profile enter T-Mobile WAP
10. Homepage enter wap.myvoicestream.com
11. Data Account select GPRS
12. Select T-Mobile WAP
13. Connection Type select HTTP
14. Proxy Address enter 216.155.165.050
15. Port enter 8080
16. User Name >Leave Blank<
17. Password >Leave Blank<
18. Press Done
19. When prompted to SAVE please select Yes
20. Select Activate Profile
21. When prompted to Activate Profile please choose Yes
22. Press Done
Create Data Account
3. Select Services
5. Select GPRS
8. Press Options
9. Press Done
11. Press Options
12. Press Done
16. Press Done
17. Press Save
Create Profile
3. Select Messages
4. Select MMS
5. Select Message Setting
6. Select Server Profile
7. Select a Profile
8. Select Edit Profile
9. Select a profile
10. Choose Edit Profile
11. Rename Profile enter T-Mobile MMS
12. Homepage enter http://216.155.174.84/servlets/mms
13. Press Options
14. Press Done
15. Data Account select GPRS
16. Select T-Mobile WAP
17. Connection Type select HTTP
18. Proxy Address enter 216.155.165.050
19. Port enter 8080
20. User Name >Leave Blank<
21. Password >Leave Blank<
22. Press Done
Reboot your phone
this should work i had the same problem
Mar 12, 2010 | Cell Phones
i have a hiphone a88 with suncom can you help
Create Data Account:
  • Select Menu
  • Select Services (Sometimes, Entertainment > Services)
  • Select Data Account
  • Select GPRS
  • Select an empty profile
  • Set the Account Name to i-Net
  • Press Options
  • Press Done
  • Set APN to internet or mobileinternet
  • Note: i think it depends on the features on account. Assuming it will be internet for full internet.
  • Press Options
  • Press Done
  • Leave Username and Password blank
  • Set Auth. Type to Normal
  • Press Done
  • Press Save
Create Profile:
  • Select Menu
  • Select WAP
  • Select Settings
  • Select Edit Profile
  • Select a profile
  • Choose Edit Profile
  • Rename Profile to i-Net
  • Set Homepage to http://mobileinternet
  • Set Data Account select GPRS
  • Select i-Net
  • Set Connection Type to HTTP
  • Set Proxy Address to 66.150.33.115
  • Set Port to 8080
  • Leave User Name Blank
  • Leave Password Blank
  • Press Done
  • When prompted to SAVE please select Yes
  • Select Activate Profile
  • When prompted to Activate Profile please choose Yes
  • Press Done
Aug 21, 2008 | RIM BlackBerry Pearl 8100
311 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
