Tip & How-To about Televison & Video
Improve wifi
To create Your windsurfer you need to cut out he following template, cut it out and cover the large square shape with foil which is glued on
Template
http://www.freeantennas.com/Templates/windsurfer.jpg.
To create this shape:
http://gallery.me.com/andrewgc1988/100009/Windsurfer1/web.jpg
http://gallery.me.com/andrewgc1988/100009/IMG_0782/web.jpg
When aiming with the windsurfer it means that the foil is facing when you want to improve reception.
Wifi reception you will need one or two windsurfers depending on number of aerials.
To improve wifi reception you need to slot the arial of the router through the x's and aim it so that it covers the area you want to improve reception.
Av transmitters will need two windsurfers one for the transmitter and one for the receiver.
You need to slot the aerials through the x's and try and aim the transmitter towards the receiver and the receiver towards the transmitter.
Although this won't be a miracle it will reduce interference
Televison & Video Logo
I need help with a quilt pattern
ask your question here by email:-
sewadvisors@nancysnotions.com
Jun 23, 2014 | Clover Trace n Create Quilt Templates with...
How can I Build a Jeep Door?
If you have a Jeep one thing you know about is accessorizing. There are a million and one accessories, kits and modifications that can be done to a Jeep. The first thing you're going to need is frame. Start by creating a template for the door opening. Start at the top front side where the hinges are and then shape the bottom and rear side. Finish the top and join the two ends together. Create a template for your design and cut out your shape. If you are going to bolt or rivet it to the frame you must leave enough material do so. Next install the door hinges. Finally install the door handles and latch. In case of any questions just visit online site of Jeep Doors and get more instructions.
Apr 04, 2013 | Cars & Trucks
How do you use a template in scrapbooking?
A template is usually a sheet made out of card or plastic that can be used to help mount or crop photos onto shapes. Some templates can be used to draw shapes and outlines onto the page. In a digital format, templates help give shape to the page and you can drag and drop your photos in the shapes of the template.
Feb 12, 2013 | Crafts & Hobbies
Can you save a text template to be put on your texts every time
Yes, it is actually called a signature. Go to your message settings and you should see signature option, select that and then add the text you want to be on your messages. But make sure that your signature is turned ON in your message settings. Hope this helps!
Mar 28, 2010 | Samsung Propel A767 Cell Phone
475 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
