Tip & How-To about Computers & Internet
How to reset your bios password.
Step 1: Power off you computer and unplug power cable.
Step 2: Open the computer case so that you can see the motherboard.
Step 3: Find the 3 pin jumper on your motherboard and put it on the other pin. Ex: If it is on 2 and 3 you will want to put it on 1 and 2.
Step 4: Plug your power cable back into you computer and turn it on. (Note: Your computer will not load you operating system.)
Step 5: Shutdown your computer and unplug it again.
Step 6: Put the jumper back into it original position.
Step 7: Plug your power cable back in and turn your computer on.
Now you bios password should be reset.
To enter the bios press the the F2 or Del key when your computer is turning on. (Note: This varies for different manufacturers.)
I hope that this helps you!
HelpDeskMan
Computers & Internet Logo
skip bios password
Try this Method:
One of the most common methods to reset the BIOS password is to remove or discharge the battery on the computer's motherboard. If the power to the battery is lost or drained, the BIOS configuration will be reset to the factory state with no password. System settings made to the BIOS will also be lost.
Step 1 - Turn off the computer and ensure it has no external power (ie unplug the power cable. If it has a battery, remove it).
Step 2 - Open the computer's case or box.
Step 3 - Locate the computer's motherboard and look for the white silver button battery on the motherboard.
Step 4 - If the battery is not soldered to the motherboard, remove it carefully and wait for approximately 30 seconds.
Step 5 - Put the computer case back together and boot the computer.
Step 6 - If the "CMOS Checksum Error-Defaults Loaded" error message is displayed, the BIOS password has been reset.
In the event the CMOS battery is soldered to the computer's motherboard, you will want to seek a different method to reset the BIOS password on the computer.
Jan 06, 2014 | Computers & Internet
BIOS
I am not sure if this is what you are looking for but this will tell you how to reset the password. If you want to know other information please ask a more detail question.
How to reset you bios password.
HelpDeskMan
Please rate this and/or leave a comment. Thank you
May 28, 2011 | Computers & Internet
what te bios password for emachine. I want to enable my ethannet which in BIOS set up. But I do not now the password of BIOS. I have not set up myself.
HelpDeskMan
May 21, 2011 | E-Machines T3418 PC Desktop
kids put wrong bios password three time the shutdown not even power come to computer
There are a few different ways to resolve this issue
1. Call the manufacturer and ask if they have a reset or a way to get the password
2. Look in the manual and see if your laptop has a jumper setting that will reset the bio (including the password)
3. Just go to the manufacturers website and get the latest bios update and flash the bios
4. Remove the cmos battery leave it out for literally a week (7days) then replace it (best if the computeris off this entire time)- this way it forgets whats saved in the bios
Mar 12, 2011 | Computers & Internet
I forgot a password bios ? I NEET HELP
You need to reset your bios.
To reset your bios, power down your computer, unplug power cable.
open the chassis and find the jumper that labeled clrtc1 near the button battery. First remove the battery. move the jumper cap from pin 1-2 to 2-3. Keep the jumper cap there for 5 ~ 10 seconds. Then put back to pin 1-2. Replace the battery. Plug the power and turn on the computer.
Dec 13, 2008 | ASUS P4SGX-MX Motherboard
367 people viewed this tip
David Payne
David Payne
