Tip & How-To about Cell Phones
Nokia n8 hard reset
With the phone turned off, press VOLUME DOWN + CAMERA key + MENU + POWER key.
or
Type *#7370# then select YES. Default phone lock code 12345
Cell Phones Logo
What's your question?hw do i reset nokia E63
To reset your Phone, there are few methods explained below:
First Method (Through Menu):
1. Switch on your Phone
2. Press Menu button, and enter to Menu -> Settings -> Phone -> Phone management -> Factory Settings -> Delete data and restore.
3. Confirm this operation -> tap Yes.
4. Now your phone will reset and restart.
Second Method (Through Code):
1. Turn on the cell phone.
2. Now tap this secret code: *#7370#
3. After that, it will ask for your lock code.(The default lock code is 12345)
4. After entering code, press OK, your handset will reset and reboot.
Third Method (Hard Reset):
1. Switch off the phone.
2. Hold and press (* key) + (3 key) + (Call button) + (Power button) all together, until you see Nokia logo.
3. Enter your lock code. (The default lock code is 12345)
4. Now your device will reset and restart.
check which method is working for you.
:Bunty
Oct 07, 2015 | Nokia Cell Phones
I have forgotten security code of nokia 1280. My IMIE No. 351671/05/037339/1. Can some body help me to retrieve or reset my security code.
  1. Make sure that your device is on.
  2. Next press and hold * key + 3 key + Call button + Power button until you see logo Nokia.
  3. Now enter your lock code.
    * The default lock code is 12345
  4. Then your phone will reset and restart.
  1. second method if first dont work .
  1. Power on the device.
  3. Then type this code: *#7370#
  4. Now press your lock code.
  5. Afterwards your phone will reset and restarts.
  6. Done!
  7. Third Method:
    1. Press Power button until your phone is on.
    2. Then navigate to Menu -> Settings -> Restore Factory Settings.
    3. Now enter your security code.
      * The default code is: 12345
    4. After that your cell phone will restarts.
Oct 21, 2014 | Nokia 1280 Cell Phone
need to do hard reset on samsung sph m910
Follow these simple steps to reset the phone
[hold the vol down button and call button press Same time and then release the power button]
and then menu appear, it work for sprint samsung intercept
Step one, Turn the power off. You need to pull the battery out and reinsert it if your phone gets frozen
Step two, Hold the Volume Down button
Step three, Press and release the Power button
Step four, a menu appears that allows for Fastbook, Recovery, Clear Storage, and Simlock
Step five, press the Volume Down button to Select Clear Storage
Step six, Press and release the Power button
Step seven, make your decision by touching one of the two options: Volume Up for YES and Volume Down for NO
If you selected YES, all data will be deleted from the phone including third-party applications. The Samsung Intercept will reboot to its original data.
Source:
http://samsung-phones-apps.com/how-to-hard-reset-samsung-intercept-sph-m910-to-factory-default-settings.html
Aug 16, 2011 | Samsung Cell Phones
I have a Nokia 5800 XpressMusic phone, I am having problems is the delivery of my sms's it goes directly to my outbox. Can anyone assist
Nokia 5800 XpressMusic Soft Reset
Using the dialing keypad type in *#7370# and then inter your lock code (default is 12345).
OR
Nokia 5800 XpressMusic Hard Reset
In order to perform a hard reset on your Nokia 5800XM, enter the following key combination
Ensure your handset is turned off then,
Press and hold the, Green key, Red key + Camera Key and press the On button.
The device will then resert in it’s default factory settings with all handset data removed.
Jun 02, 2010 | Nokia 5800 XpressMusic Smartphone
How to put Key pad lock code on n73
foloow the folowing 2 ways
  1. Tools->settings->security->phone and sim->autolock period->user defined->type the minutes. This will automatically lock ur phone after the desired time u have set.
  2. Press the power button on top of ur phone. Menu will appear go down and select lock phone option..
Default lock code is 12345
Aug 29, 2009 | Nokia N73 Cellular Phone
294 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
