Tip & How-To about Lands Phones
Avaya Partner Phone System Programming
Programming Without Button Overlays:
Although it is advisable to have a Partner programming manual and overlays when performing changes. Here are the basic steps for changing system time, day and date. The "Feature" key is self explanatory while other keys need a reference. "System Program" key is the left intercom key on the phone. The "Central Tel" key is the right intercom key. The "Next Data" key is the third key from the left with an LED on the top row of an 18 Button display set. Numbers # and * are simply entered as numbers of the dial pad.
Avaya Partner System Date Program #101
Use this program to set the month, day and year. The system displays only the month and day on display telephones when the telephone is idle: the month, day and year also print out on SMDR call reports when used.
Considerations:
The System Date date-stamps the back up files when you use Backup Programming.
The "Feature" key is self explanatory while other keys need a reference. "System Program" key is the left intercom key on the phone. The "Central Tel" key is the right intercom key. Numbers are simply entered as numbers of the dial pad.
Programming: To change system date: Press Feature, 00, System Program, System Program,#,101 at extension 10 or 11. Enter today's date in the form of "mmddyy" (Month, day, and year), including leading zeros for single digit months or days. For example, to enter April 26 2003, press 042603. A display similar to the following appears: System Date Data 042603. Exit programming mode by pressing Feature, 00 or lifting and hanging up the handset.
Avaya Partner System Day Program #102
Use this program to set the day of the week that appears on system display telephones.
Programming: To change system day: Press Feature, 00, System Program, System Program,#,102 at extension 10 or 11. Change the day by pressing "Next Data" until the day you want appears:
1=Sunday
2=Monday
3=Tuesday
4=Wednesday
5=Thursday
6=Friday
Avaya Partner System Time Program #103
Considerations:
Enter the time in 24 hour notation. In this scheme, the hours of the day are 0000 (12 midnight) to 2459 (11:59). Since each time must have four digits, use leading zeros when necessary. The time appears on system phones as A.M. or P.M., not 24 hour notation.
Programming:
To change system time: Press Feature, 00, System Program, System Program, #,103 at extension 10 or 11. Enter a new time in 24 hour notation. For example, to set time to 2:15 P.M., press 1415. This time will appear on the phone as 2:15 P. Select next procedure or exit programming mode by pressing Feature, 00 or lifting and hanging up the handset.
Lands Phones Logo
caller id partner
To program a Caller ID Name Display button using remote administration on Partner ACS Release 3 or later systems:
  1. In the Partner ACS R3 System window, select Extensions. The Extensions window appears.
  2. Select the extension you want to program. The Individual Extension Parameters window appears for the selected extension.
  3. Select the Button Programming button. The Button Programming window appears for the selected extension.
  4. Optional - For new systems where no download is available: From the Phone Model box, select the arrow and choose Partner-34D, Partner-18D, Partner-18 Non-display, Partner/MLS-6 Non-display, MLC-6 Cordless, MLS-12 Non-display, MLS-12D, MLS-18D, or MLS-34D for this extension. The button layout for the type of phone you selected appears.
  5. Select the button you want to program. The Partner Set Button Programming Information dialog box appears.
  6. Select the Caller ID Name Display button.
  7. When you are finished, select the OK button.
  8. Repeat steps 5 to 7 to program other buttons for this extension.
May 22, 2014 | Avaya Eurostyle 18D Corded Phone
I work with hand drawn illustrations that I scan as bitmaps and would like to change theminto vector based illustrations to colour them in using either illustrator or photoshop. Open paths are a problem while colouring in the illustrations so how would I close open paths on these vectors?
You can either close the vectors, completing the autotrace (I assume you are autotracing) or you can draw shapes into the spaces and color the shapes. This is akin to color overlays, then send the overlays behind the line art.
It depends on the complexity of the artwork. You may need to touch up your illustrations so your shapes are complete in the drawing, that would probably be the most time-effective way to solve this problem. Fixing the vectors or tracing in the color overlays (underlays if you will) can be time consuming.
Jan 06, 2010 | Computers & Internet
Templates
Hi there, most of the time, the technicians leave these Programming Overlays in the box, or in a box next to the telephone system.
You can look up these overlays via Google, or look for the programming template. We cannot tell you which buttons are for what, because each button can be programmed as something different on every set.
But here is a non-picture of the template... Now you will have to look at your LCD for 3 arrows
<- Heading....Enter->
<- Back .......Next->
You will not see these words in the LCD display, you just have to look for the 3 arrows that correspond.
Or you can look at this link below for a picture representation...
http://www.freevoicetelecom.com/docs/norstar_programming_basics.pdf
Good Luck!
Jul 29, 2009 | NorStar T7316E Corded Phone
Programming Page Button
You could look in the station user's guide and program paging. This may work, or not, if you're paging internal and outside do this:
From your phone press Feature 00 the button and then Intercom *70.
If you don't want all the idle phones in group 1, but just the outside speaker, press 70 alone.
I'm not positive, but you may have to delete the button in centralized programming if it is already assigned a "CO" line.
Centralized programming is done from extension 10 or 11 and involves the system manual and knowing where the overlay buttons are.
Post back if you need a basic Partner ACS manual or try www.avaya.com for system manuals.
Carl
Feb 20, 2009 | Avaya Corded Phone avaparp18d
Video Problems with Windows Media Player
Why is the projected video black in the Player? If you can see the Player, but the Video and Visualization pane is black, this usually indicates that your video card is not configured correctly. You can usually correct this problem by changing the video acceleration and/or overlay settings for your video card. To change video acceleration, do the following: 1. In Windows Media Player, on the Tools menu, click Options. 2. In the Options dialog box, click the Performance tab. 3. In the Video Acceleration area, move the slider to adjust the video-acceleration capabilities of your video hardware. Drag the slider to Full to use all available video acceleration. Drag the slider to None to use basic video-acceleration settings that work with most video hardware. To change overlay settings, do the following: 1. In Windows Media Player, on the Tools menu, click Options. 2. In the Options dialog box, click the Performance tab. 3. In the Video Acceleration area, click the Advanced button. 4. In the Video Acceleration Settings dialog box, under Video Acceleration, clear the Use overlays check box.
Aug 18, 2007 | Smart Technologies SMART Board 580 (SB580)
2,041 people viewed this tip
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
