Tip & How-To about Computers & Internet
Getting the most out of a Home Network
A wired connection is still the best way to get maximum download and upload speeds because your computer is directly connected to your gateway/router via an Ethernet cable. While this method offers consistent speed, it might not be convenient running multiple PCs and Laptops with a wire in your home.
Improving your wireless connections:
1. Do not use wireless connections where it is not needed or not important.
Devices that are not moved frequently such as a printer or a desktop PC can use the ethernet cable to minimize traffic in the wireless connection. Some home users use a wireless adapter for their desktop PC to connect wirelessly which I think is irrelevant not unless your desktop PC is really far from the router. Most routers provide 4 ethernet ports which you can use for the printer and desktop PC.
2. Make sure that your Wireless Network has WEP/WPA enabled.
All routers are equipped with security features that can provide passwords to your network. A secure network is less susceptible to unathorized use of your network. The more users use your network, the slower it becomes.
Sample video on how to secure your network using a LinkSys Router:
3. Get a better range.
Depending on how your home is designed, your wireless gateway may not be able to reach certain parts of the home, but you may be able to improve access to those trouble spots. There are several companies that have developed wireless repeaters (sometimes called a signal booster), devices that can pick up the signal from your router and extend that signal to other parts of the house. It should be noted that any repeater has its own limitations and the greater your distance from the repeater the weaker your signal and the slower your speed will be.
4. Change your wireless channel to reduce interference.
You may experience weak or dropped signals if a cordless phone or any other electronic device and your wireless router share the same frequency channel. A potential fix for this issue is to change the channel, thereby reducing frequency interference. The wireless channel can be can be accessed in the wireless settings of your routers interface. Channels to choose from are Channels 1 to 11. This should be done in a trial and error method, choose whatever channel delivers the most speed.
Sample video on how to change the wireless channel on a Zoom Router:
5. Make sure that you are running the latest firmware and driver updates.
One of the easiest steps to improve your connection speed is to make sure you are running the latest software updates for your wireless adapter. If you are, the next step would be to check if your network card has been updated with the latest drivers. To confirm that you have the latest drivers available, go to the wireless card manufacturer's website and look for a Support and/or Driver link. If you have a built in wireless client (one that cannot be removed from your PC), check to see if your PC manufacturer has issued any updates.
The above tips has greatly improved our home network which consists of a Prolink router, 2 netbooks, 1 laptop, 1 desktop pc, 1 printer and an occasional use of mobile phones to connect to the internet.
Thank you for using FixYa!
Have a great day!
Jas247
Computers & Internet Logo
Netgear N300 is slowing down my internet connection
The router limits the data speed to the wireless reception.
802.11 G speed (maximum) is 54Mbps.
Jul 17, 2013 | NetGear N300 Wireless Router
belkin n150 download speeds are low
Low Download speed may be due to various conditions such as,
* If your Internet connection is shared with others on your LAN and they are using up all the available bandwidth. Tell them to knock it off
* Your ISP may be limiting your P2P traffic via some method of packet shaping. Call up the ISP and inquire if they do anything with P2P traffic.
* Check whether you haven set up your third party firewall or internet monitor software correctly.
* Your computer might have been infected with malicious software which altered the low level network settings of your operating system.
* You need to optimize your operating system for your current connection speed. First, close all P2P applications. Next run the DSLReports TweakTest. Once you have optimized it, then run a speed test at www.ScanMySpeed.Com This will give you a good idea what your maximum download and upload speeds are. If you're getting within 10% of your connection speed, that's the best you can get! If you are having trouble with your connection, and it relates to packet loss, excessive latency, or Internet or ISP congestion, running the Line Quality Test may help find the cause
Nov 24, 2012 | Belkin Connect N150 Wireless N Router
network keeps on crashing
Try turning QOS off on your router. Generally, with home routers, QOS causes issues. What are your download and upload speeds? If you don't know you can go to speedtest.net and it will tell you. If turning off QOS doesn't resolve your issue and you have decent Upload/Download Speeds (3mbps/20mbps or higher) then your best bet would be to replace your wireless router.
Apr 14, 2017 | NetGear WNDR3400 N600 Wireless Dual Band...
What is the maximum speed
The speed of that router is 100 mbps (wired) and 54 mbps (wireless). If you have a 1 mbps line, that router is more than sufficient. Your speed will change simply because someone is using the internet connection. Downloading, uploading, surfing, chatting, listening to internet radio, etc. Make sure no one is on, then test it to see what speed you get. Go to www.speakeasy.net/speedtest and select the server nearest to you. It is a very good speed tester.
Good Luck!
Dec 05, 2008 | NetGear WGR614 Wireless Router
911 people viewed this tip
David Payne
David Payne
