Tip & How-To about Computers & Internet
How to improve cpu or pc perfomance?
1.Cleanup disk
-Cleanup disk mean clean and clear all temporary file. Such as browsing history, temporary file when you browse internet, temporary file where that was save when you install something or else.
- If you don't know how to clean up? windows also have tool for clean up disk, but i'm more prefer using ccleaner software. It is freeware and does not need waiting to long. Just check the check box where the file and data that you wan to delete. It also came with registry fix and you also can set start up software. I'm like this, because with lower hardware, we need to less startup program. Then here i'm choose to startup program antivirus only to make my logon to window and ready to use more faster.
2.De fragment
-ARRANGE FILE AND DATA.
-Why we need this arrangement back?
#storage that you use is like the warehouse. Where all file and data like the product that you save in warehouse. What ever type of your warehouse and product, if you don;t arrange properly then it will difficult to find specific product right? During you install and using storage, it will default to save all new file or modified file, data to empty space. It will put anywhere in your storage. That why we need to fragment it back. For to know whether you should or not to defragment then use defragment tools (from window or defraggler-freeware) to analyze your storage. It will tell your whether you need or not to proceed to defragment. For me, as long i'm see red graph or box . I will defrag my storage.
3.Checking disk
- Checking disk for find bad sector in drive. It was cause from virus damage or from some heavy program like in gaming with high graphic.
There are many way we can check our storage have bad sector or not. Using cmd if you know the command. I'm like to use this. How ever, if you don't know, you can try tools from window. Google and type CHECKING DISK IN WINDOW
4.Change to performance for PC or LAPTOP with lower requirement.
-Before 2010, I using pc with Pentium 4, 1.7Ghz AND 256MB sdram.
with 20GB hard disk. It make me frust sometimes when it hang and need to clean up the disk for more empty space.
For to make my cpu work at optimize perfomance then I change my pc to performance option.
Right click to Computer. cHOOSE properties and in seconds(depend cpu performance) window will pop up and find Advanced Setting.
Then find perfomance tab then at radio button, chose performance. It will change your theme, after you apply it. it will look classic but I don't care for visual, because I'm need more performance then visual effect and beautiful theme.
You also can google how to change perfomance.
Computers & Internet Logo
Periodically (but rather frequently now,) when I click on a link such as "copy" or "history," the link stays on the screen. Even when explorer is closed it is still on the desk top screen untill I reboot
May be it is because of virus problem, Scan your computer with latest updated Antivirus.You can try by using Disk cleanup utility, Disk defragmentation, Delete all Temporary file, Then Restart computer.Delete all browsing history and internet temporary file.I am sure ,It solves your problem.
1. Start >All Programs> Accessories>System Tools>Disk Cleanup
>Disk Defragmenter
2. Start > Run > %tmp% then OK.--Select all Files and Folders and Delete It.
May 09, 2011 | Computers & Internet
how do clean my cache
to clean your cache, there are two ways... One is to open your Internet browser, click Tools > Options > Clear Browsing History > Check boxes on cookies , private data etc. Another way is to clean your temporary files by clicking Start > All Programs > Accessories > System Tools > Disc cleanup.. Check box on delete Temporary files and click OK. Those ways will help you clean your cache...
Jan 28, 2011 | Computers & Internet
clear internet temporary files
Open internet Explorer - click Tools - Options (in Menu)
in General tabs you will see the button - Delete...
Press it to delete all temporary internet files
Nov 19, 2010 | Microsoft Internet Explorer 7
when try to sign in it says cookies won.t allow it i neeed access to my email what do i do cookies seem to be preventing me from logging on to get to my email
I assume you are using Internet Explorer as your browser. Open the Control Panel > Internet Options > General > and below the general tab, locate "browsing history", select "delete browsing history on exit", click "Delete" > "Apply" > "Ok" (you have to do this while the internet explorer is closed, otherwise all the cookies and temporary files will be unable to delete).
Now open the internet explorer and access the site again. Hope it's gone now and you can access your mails.
If in case the problem persists, you need to use a system cleaner, (click here to download a cleaner-freeware) or run the disk clean-up wizard, open "My Computer" right-click C: > "Properties" > "Disk Cleanup" > on the disk cleanup wizard dialog box options, select the applicable location/programs including Temporary internet files and Temporary files, click "Ok".
[If you are using another browser like Mozilla firefox, googlechrome, etc..etc.. it's best and easiest to run the program mentioned above, but always run the program while the browser is closed]
That'll definitely fix your problem.
Good luck.
Thanks for using FixYa.
Aug 14, 2010 | Yahoo Mail
clear browsing history
On the internet, assuming your using Internet Explorer, you would go to Tools (on the menu bar) and click on "Delete Browsing History..."
On your Computer you can try using Disk Cleanup. It would normally be located in the Start menu (windows button):
Start (windows button) --> All Programs --> Accessories --> System Tools --> Disk Cleanup
Mar 18, 2010 | Microsoft Windows XP Home Edition
215 people viewed this tip
David Payne
David Payne
