Tip & How-To about Cell Phones
How to get Puk and pin code
Hello !
Because number of caractere it was not enough i write my tip in picture below
Or check this
http://data.imagup.com/7/1120983391.gif
Cell Phones Logo
I get an error message saying I have a jam in door c I don't have the door c how do I fix this
We encourage you to use our knowledgebase, MRC Smart Technology Solutions is here to help! We offer a program to cover up to 3 printers of any manufacturer for an entire year!
We can solve your problem!
Email patrick@mrc360.com for more info.
I found the following on our knowledgebase at http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=36,E=0000000000016136485,K=3441,Sxi=8,Solution=obj(1513)
The pictures may not come through below, simply click on the link above or below to be taken to the page directly.
Resolving Jams at C
Perform the following steps to resolve Jams at C.
  1. Slide the 2000 Sheet Feeder (Tray 6, if installed) away from the printer (See Fig. 1).
  2. Fig. 1 [img src="http://www.support.xerox.com/infosmart/spower/data/media/image/Hardware/Phaser5500/move_tray6.gif" alt="Move Tray 6">
  3. Open Door C (See Fig. 2).
  4. Fig. 2 [img src="http://www.support.xerox.com/infosmart/spower/data/media/image/Hardware/Phaser5500/open_door_c.gif" alt="Open Door C">
  5. Check for and remove any jammed paper. Make sure that all paper fragments have been removed.
  6. Close Door C by making sure the door has latched securely at the front and rear of the printer.
[img src="http://www.support.xerox.com/infosmart/spower/data/media/image/ALL/note_image33x30.gif" width="33" height="30" border="0"> Note: If Door C is not secured completely, jams inside Door C and/or skewed prints may occur frequently.
  1. Slide the 2000 Sheet Feeder (Tray 6, if installed) firmly against the printer.
  2. Verify the paper is loaded correctly in the tray being used. Reference Loading Paper Trays 1-6 for additional information.
  3. Try turning the stack of paper over in the paper tray being used. Make sure the paper meets the printers specifications. Reference All About Media for additional information.
  4. If the jamming continues from Tray(s) 4 through 6, refer to Cleaning or Replacing the Pick Rollers for additional troubleshooting.
Oct 17, 2014 | Xerox Xer 5550_dt Phaser 5550/dt - Laser...
how do you empty the trash in gmail
Hi!
see the pictures bellow
http://www.imagup.com/data/1120786251.html
May 23, 2011 | Motorola Cell Phones
What i would search if i finding taylor swift moving pictures????
The "moving pictures" you are referring to a GIF-formatted pictures. To find animated GIFs of Taylor Swift, go to google and search "Taylor Swift GIF", that should yield many results and great pictures of her.
Here are a few links with GIFs of Taylor Swift. Cheers!
Apr 20, 2011 | Cameras
change headlight
hello. below is the procedure for removal of the headlamp for bulb replacement. to access the headlamp you will need to remove the bumper fascia. http://gsi.xw.gm.com/image_en_us/gif/000/001/725/1725371.gif Callout Component Name 1 Front Compartment Sight Shield Plastic Retainers (Qty: 6) 2 Front Compartment Sight Shields (Qty: 3) Tip Each front compartment sight shield is serviced separately as needed for repairs http://gsi.xw.gm.com/image_en_us/gif/000/001/728/1728611.gif Callout Component Name Preliminary Procedure Remove the front wheelhouse liner. Refer to Front Wheelhouse Liner Replacement . 1 Front Fascia Extension Plastic Retainers (Qty: 5) 2 Front Fascia Extension http://gsi.xw.gm.com/image_en_us/gif/000/001/733/1733942.gif Callout Component Name Notice: Refer to Fastener Notice in the Preface section. Fastener Tightening Specifications: Refer to Fastener Tightening Specifications . Preliminary Procedures Remove the front compartment sight shields. Remove both front bumper fascia extensions. 1 Front Bumper Fascia Reinforcement Nut (Qty: 2) Tighten 6 N·m (53 lb in) 2 Front Bumper Fascia http://gsi.xw.gm.com/image_en_us/gif/000/001/736/1736893.gif Callout Component Name Notice: Refer to Fastener Notice in the Preface section. Fastener Tightening Specifications: Refer to Fastener Tightening Specifications . Preliminary Procedure Remove the front bumper fascia. 1 Headlamp Nut (Qty: 1) Tighten 6 N·m (53 lb in) 2 Headlamp Bolts (Qty: 3) Tighten 6 N·m (53 lb in) 3 Headlamp Assembly
Jun 13, 2009 | 2003 Cadillac CTS
Timer problem
Found on partselect.com MAYTAG
Wiring diagrams:
http://www.partselect.com/Schematics/Maytag/52485.gif
data on the whole thing:
7 diagrams
Sep 24, 2008 | Maytag PYE2300AY Electric Dryer
346 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
