Tip & How-To about Computers & Internet
How to Recover Lost Data from Crashed Hard Drive?
The worst thing about crashing your computer is losing all your data. Pictures of years precious memories, importantdocuments in your business and current projects of weeks hard working---all arelost unless you have backed them up on a CD or memory stick. If that is it,it's heartbreaking!
There are still hopesfor retrieve your data. Taking the computer to arepair service is one solution. But it is so expensive (usually costs $1000 ormore), especially when recovering data.
However, you can retrieve the lostdata from the crashed hard drive by yourself! Here is a step by step guidefor you to do so:
The first thing you should do
is toremove the crashed drive from the computer and install it as a secondary drivein another computer operating Windows Os. Make sure that it is detecting by thecomputer.After youhave set up the secondary drive, boot up Windows. Then you can copy and pasteyour files from the drive.
However, there are may be two trouble. One, you can'taccess the drive (means you can't open it); Two, your files are retrieved butyou can't open it!
Don't panic!Just download a data recovery program, and with a few simple clicks, you willbe able get your data back. Thereare some costly windows tools available for this. Here I recommend you two cheap ones:
>>Recuva
>>TenorshareData Recovery
Recuva is a free one. It doesn't work in very extreme casethough. It may turn out that your files are recovered but you can't open them. Ifthat's the problem there are more serious software solutions for this, like Tenorshare Data Recovery. It costs a bit but much more effective.
Next,
downloadTenorshare Data Recovery here. Be careful, do not install it to the drive that you are tryingto recover. Doing so could actually overwrite files that you want to restore.Install it on the primary drive that you are booting from.
Last,
when you use thistool, select 'Partition Recovery'. And within several clicks, you can retrieveall your data!
Besides,
if the hard drivecan't be recognized, you can try this trick. Put it in a sealed plastic bag toavoid condensation. Then put the drive in a freezer and leave it overnight.When you are ready, pull the drive out of the freezer and hook it up quickly.Act quickly because you may only have around 20 minutes to do this. I have seensome reports however, of this fixing the problem all together.
If it fails,
you will have to goto a recovery office (where offers recovery service) but let's hope not becauseit will cost you a lot of money and whether they can recover the data is notguaranteed.
Tips & Warnings:b>
  • The recovery tool mentioned above only supports for all almost Windows platforms such as Windows 98/2000/2003/NT, Windows XP, Windows 7, Vista. For Mac, you can google search to get one.
  • Find a friend who is good at computer to help you.
  • If your computer crashed because of a virus, copy the files to an external hard drive. Do not move directly to a new computer.
  • Hard drives are fragile. Be careful and do not drop it.
  • Run your antivirus software regularly.
Related Articles:
howto Recover deleted files from Windows Xp?http://www.tomshardware.com/forum/258790
howto Recover Deleted Photos, Videos from Nikon Digital Camera's SD Card?
http://www.progtalk.com/viewarticle.aspx?articleid=4580
howto Recover Deleted Files from Memory Card of BlackBerry Mobile Phone?
http://www.pubarticles.com/article-how-to-recover-deleted-files
Computers & Internet Logo
I don't know what happened but my pictures are gone and I don't know how to get them back! Please help!!?!
Assuming you didn't download the pictures to your computer ... and as part of the download option, you elected to erase/remove the pictures (after downloading them) from the camera ... and you have not done anything (on the camera menu) to "refresh" or erase the pictures, or reformat the storage media (memory card) ...
then ...
... if the pictures are stored in a memory card .... you can take that memory card out of the camera, insert it into your computer ( ... or use a card reader, inserted into a USB port) ... and see if you can recover the "deleted" data from the memory card ...
... if the camera only has "internal" memory ... connect the camera to your computer ... and when it shows up as a storage media, try to recover the "deleted" data from the memory card ...
You can (find on the Internet) and install and use various (free) software (on your computer) to recover "deleted" files on storage media (memory card, etc.), ... on a Windows PC ... like PhotoRec, PC Inspector File Recovery, Undelete Plus (or Undelete 360), Glary Undelete, Wise Data Recovery, Recuva Free.
Apr 03, 2014 | Cameras
Camera was not disconnected from the USB correctly and now comes up with card not initialised. Can this problem be fixed without losing the photos?
Don't worry, your lost photos that are very precious can be recovered with ease. I would like to introduce you a very good data Recovery software, called tenorshare data recovery which can be used to recover images from SD card and from other storage devices. This software is an assortment of data recovery components designed for recovering deleted / lost files and folders, photos, RAW images, music & video files from crashed, re-partitioned, accidentally formatted partitions & drives.
You can get it from: http://www.any-data-recovery.com/
Jan 15, 2011 | Fuji FinePix S5000 Digital Camera
h/p desk top pc,xp exdition
If computer starts up all the way in safe mode, you have a better chance of salvaging this system.
If not, the hard drive may be crashed (physical damage, scraping oxide from the platters).
Worst case, you would have to replace hard drive and re-install windows and everything else.
Best case, a repair function can be done from a winXP CD that will replace windows files without erasing anything else.
If there is precious data on the hard drive, a data recovery may be in order.
I can provide a reliable and reasonable source for this service if needed.
Oct 25, 2008 | Computers & Internet
Windows XP Home Edition on HP Pavilion a367c
Are you able to successfully enter Safe Mode? Are you getting a brief blue screen before the computer restarts?
A possible solution (if you can't get into Safe Mode to further diagnose the issue) is to repair the Windows installation with a Windows XP Home CD. If you know someone with such a disk you can use that with the product key that should be on a sticker on the back of your computer. Otherwise, HP should be able to send you an XP CD since you have an authorized copy of Windows on your computer.
May 14, 2008 | Computers & Internet
Memory card malfunction...
If the photos are important the first thing you want to do is get a memory card reader and use it to get the pictures off the card. A SD card reader can be found for about $5 bucks online and it will let you simply COPY and paste the pictures onto a folder on your computer. Make sure you COPY and not CUT because in case something goes wrong during the transfer you won't lose your precious photos.
It is possible that the camera driver is corrupted or deleted on your computer. Honestly it is not worth the hassle to deal with the camera drivers... it is much easier (and faster) to transfer the photos using a card reader.
Sep 08, 2007 | HP Photosmart M417 Digital Camera
228 people viewed this tip
David Payne
David Payne
