Tip & How-To about Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut
Ignition Won't start ?
We have a 48" cut Husqvarna riding tractor ....
1. Check oil. If its low , add oil to fill mark on dip stick.
2. Check ignition fuse. Our's took a 20 amp fuse.
It started right up.
We have a lot of pot-holes in our town. The fuse wire must have jiggled and touched against the frame. It blew the fuse.
Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut Logo
Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut hydrostatic transmission slipping
first i would check the belt tension also check the belt for oil is so look for the cause of the leak the repair the leak and replace the belt
Jul 30, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
oil dipstick tube broke
look on dip stick you should see cross hatched area with add oil or oil full mark.if you wipe oil dip stick with a clean paper towel and dip stick look dry no sign of oil add little oil at a time see if oil level reach add oil mark or the full mark.if oil is low. low oil light will turn on if bulb is blowed but if dip stick look dry oil level could be low,add little bit at a time dont over fill.
Feb 16, 2012 | Cars & Trucks
oil change
Probably about 1 1/2 quart ... you will have to confirm the fill with the dip stick. Do not over fill .. Put in 1 quart ... start the engine ... let it run for 30 seconds of so ... shut it off and check the dip stick.
May 31, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
what kind of oil for a husqvarna riding mower?
Yes SAE 30 is the recommended oil for B & S engines. You can find it on amazon for good price. here: Amazon com oil 30w . Hope this was helpful. cheers
Jun 14, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
2,156 people viewed this tip
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
