Tip & How-To about Computers & Internet
Monitor is Black, Computer won't boot, computer screen is black.
If you have power and you hear your computer running but screen is black, your cables are connected and screen power button is on, No dots, dashes, words at all, usually that indicates the graphics card or ram is blown. Much more rarely a bad CD/DVD drive defect can block motherboard monitor drive.
Usually there is a used computer parts dealer in major cities and fault confirmation can cost under $10.00 if you can switch graphics cards yourself. Take your card in with you for slot style matchup. Nearly all computers can handle a card switch without data loss. Labor and time saving to try a card with Windows drivers resident, buy a universal or common brand.
Computers & Internet Logo
my garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
i have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
black screen, hear voices , but no picture playing?
check your screen back Light or get a working screen and test it or your screen flax is bad
Mar 31, 2017 | Mitsubishi WD-73C9 73" DLP TV
vostro 1000 black screen an i can hear it running, but can see..
A blank screen with evidence that the motherboard is working (the Capital "A" green light is probably the CAPS LOCK on your computer's keyboard) initially points to an output or video problem. One quick way to see if that is the case is if you connect the computer to an alternate screen. Do so with the "sick" computer powered off at first. After being sure the connections are snug, be sure that the test monitor is powered on and then turn on your "sick" Dell. If the test monitor runs as your laptop's monitor ran when it was healthy then you know there is a cabling/backlight/inverter/screen problem. Some of these can be solved very easily, some more expensively as replacement may be required.
On some laptops pressing down firmly on the keyboard may seat a screen cable to motherboard connection. That often works on IBM Thinkpads with screens that fade in and out due to a poorly seated screen cable connection to the motherboard.
So let's see how the test to a known working screen goes.
Apr 18, 2009 | Dell Vostro 1000 Notebook
Screen black
Take the post (power on self test) disconnect vga cable and connect power cable if monitor shows no signal check signal cable massage then monitor is ok fault is in cpu. open it and clean the dust
by vaccum cleaner you will get the display again
Oct 17, 2008 | X2Gen MG19MY 19" LCD Monitor
271 people viewed this tip
David Payne
David Payne
